Question about Whirlpool GS563LXS Kitchen Range
When oven is baking, control resets
There is an intermintent problem. Every once and a while when oven relights to maintain set temp the control resets and clock blinks.
  • 213 Answers
Theres a loose conection on the oven control more than likely its internal and youll need to replace the control but check you wirs to the control first just incase the bad conection is there. if its not, replace the oven control
Posted on Nov 25, 2007
Oven will not relight
Hi. This is quite common with gas ranges of this nature. I will list the most common culprits below:
1. Gas valve coil assembly malfunction(Most likely culprit)
2. Ignition Faults(damaged ignitor)
3. Oven temperature sensor faults(unable to read oven temp)
4. Main logic board or PCB damage(Control board issues)
I would advise to unplug the unit for five minutes. This will induce a hard reset that will reset the main board. Once this is done, plug or reintroduce power to the unit and try to preform a normal baking session. observe the ovens actions. If the faults persist, Start your troubleshooting by checking the sensor(oven temp sensor) for faults. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test).
The most common oven sensors should be approximately 1100 ohms at room temperature. Other temperatures are as follows:
100F - 1143 ohms
200F - 1350 ohms
300F - 1553 ohms
(You will essentially want to test it at room temp)
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
If the sensor checks out ok and the wiring is connected without any faults, move on to the other areas of concern. I will list the other procedures below.
Oct 26, 2011 | Hotpoint RGB745 Gas Kitchen Range
We have a Maytag CRG9700BAL. The Oven Will light and come to temp but will not relight to maintain temp. We have replaced the oven temp sensor and the clock assembly but the problem persists. Could the...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Feb 21, 2011 | Maytag Kitchen Ranges
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Kenmore SF367.....Contantly relighting during cooking?
This is a normal function of your gas range. I own a similar model and it operates the same way. The gas is not required to be on continuously to maintain the oven temperature and will relight periodically when the internal temperature drops below the prescribed set level.
Jul 04, 2009 | Whirlpool SF367 Gas Kitchen Range
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Oven temp
You could have a weak oven ignitor. If it has a "glowbar" style ignitor they get weak after while and will light once or twice nd then wont be drawing enough energy to open the gas valve on subsequent attempts. You can check only with a clamp on amp meter. If under 3 ampa replace the ignitor.
Apr 12, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Whirlpool super capacity 465
I use the plastic zip ties to hold connecters on cars fairly often I would think this part of the oven is cool enough.
Gene 243
Dec 24, 2007 | Whirlpool GS460 Gas Kitchen Range
Open Questions:
This range has worked fine for over 3 years. We use the oven a lot, the broiler not often. Last evening after using the stove for several things, then the broiler very briefly, both of them stopped working. The "Preheat" display comes on, then you hear the loud click (which I assume is an electronic valve), then instead of hearing the burners ignite, you get another loud click, no ignition. The stovetop burners all work. -------------------------------------------------------------------------------- Following up on my own question here, I found a document online titled Whirlpool Gas Range Direct Spark Ignition System, which applies to this range. I got a multimeter, followed the directions in the document. Seemingly this procedure indicated this Spark Ignition Module, which controls both the broiler igniter and the bake (oven) igniter, was bad. Then, just to be thorough, I tested the double solenoid which is part of the electronic Gas Distribution Valve which runs gas to the bake burners and the broil burners. The broil terminal was dead. This manual says if one is dead, neither will operate. The solenoid is tested when it is disconnected from the oven. The solenoid IS connected when you test the spark ignition system. So, my tester showed two problems, and for either one, the manual says replace it. But, it's hard to believe both parts went bad at the same timel So, I hope the gas distribution valve solenoid is the whole problem. Anyway, I going to replace that first, and see what happens. Does that make sense?
Feb 28, 2017 | Whirlpool GS563LXS Kitchen Range
Whirlpool GS563LXS Kitchen Range Logo
176 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
