Question about Toshiba SD-5000
Product code for remotes programming
SD 5000 Toshiba
dvd progressive
2 Suggested Answers
SOURCE: toshiba sd 3990 dvd player remote code
have fun most trutech devices are daewoo codes and unless you have one of these 100.00 harmonix controllers from logitiech you cannot due jack
Posted on Nov 21, 2007
  • 12 Answers
SOURCE: Unlock region code for Toshiba SD-5000
what make of dvd player do you have?
make and model
Posted on Jan 18, 2008
0 characters
1 Points
Need codes for he universal remote to program to Toshiba DVD player SD-1800
Use the code search provision of your universal remote to seek a suitable code. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jun 03, 2016 | Toshiba SD-1800 DVD Player
How do I program a RCA universal remote to my Toshiba SD-V392 vhs/dvd combo player
Turn on device , look up the code number for a Toshiba vhs/DVD combo then press setup and hold until it blinks then press device vhs/DVDs then enter code and press off button when device turns off it is programmed
Aug 29, 2015 | Toshiba DVD & Blu-Ray Players
Remote menu button not working
Sometimes you can enter a code that will work nearly all the buttons, but is not the correct code for your DVD player. You should try other codes. But sometimes a universal remote will NOT work every function.
Dec 22, 2012 | Toshiba SD-V392 DVD Player/VCR
Toshiba sd-5000 just not playing. all HDMI cables are properly plugged in. Accidentally push a "strange button on the remote and the DVD player just topped working. The LCD shows that it is working, but my...
I got the same problem today. I thought it was a connection on HDMI cable problem. I tried many different options to solve it but nothing was working. After I read your post I realized that my 2 y old boy was playing with the remote before it happened. So I found on menu in DVD player option - default setting- and I pressed it - and bingo - it's working. I used cinch cables instead HDMI while I was fixing - just in case you cannot get the menu screen on tv - good luck
Jan 20, 2010 | Toshiba SD-5000
Trying to program comcast remote to work with my toshiba SD-V290. Need the remote code??? go there and click the remote your using and then find the brand and get the code
Jul 12, 2009 | Toshiba SD-V296 DVD Player/VCR
I need to program a universal remote for a Toshiba SD-K510.
it is 1110 the code for Toshiba SD-K510 it works on mine Toshiba SD-K510 the code on mine universal remote
Jun 07, 2009 | Toshiba SD-K510 DVD Player
Unlock code
does the remote have a memory button?
Apr 22, 2008 | Toshiba SD-5000
Diamond Vision Progressive Scan DVD Player
The only Diamond Vision Codes I can find are these.
Hope one works for you.
0622, 0496, 0810
Have a nice day!
Feb 24, 2008 | DVD & Blu-Ray Players
make and model
Jan 18, 2008 | Toshiba SD-5000
Region free?Toshiba SD-140E
Put DVD into player - wait for regional code violation screen to appear. Once this happens press the M (Memory) button on your remote control. Then press 1 for Title 1 and press play on the remote. This will over-ride the regional code violation detection menu and you can watch the movie etc by entering the fwd on the remote control and change chapters etc by using the T (Title/Chapter) button on the remote control)
I found this for other Toshiba SD dvd players, yours was not listed but might be worth a go.
Oct 25, 2007 | Toshiba SD-140E DVD Player
Toshiba SD-5000 Logo
Top Toshiba DVD & Blu-Ray Players Experts
Are you a Toshiba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
