Question about Dell Computers & Internet
I need to find out if I still have a built-in recorder with Vista
I changed my hardrive and installed Windows Vista Home Premium, I have been attempting to record music that I am sending from my Yamaha Musical keyboard, I have Audacity which is musical editing software that is made to work in conjunction with the recorder in my computer. However, now that I switched to Vista I can't seem to find or use the built in recorder, It worked when i was using Windows XP pro. all that is now listed in the device manager under audio,video and game contollers is the Soundmax sound card.
  • 2 more comments
  • Steve Caulfield Jul 31, 2009
    In the past I have not needed drivers for my Yamaha keyboard. I am only sending prerecorded music fron the keyboard to my computer. The keyboard has not ever shown up in my device manager even when I was successfully doing this with XP. I'm sending an audio signal from the Yamaha keyboard to the computer over an audio cable to the computer's mic in. What is not showing up is the computer's recorder. I would need a driver for the keyboard if I were using the USB cables and Musicsoft downloader.
    I haven't needed drivers for my Yamaha keyboard before.I'm sending an audio signal across audio cable from my keyboard's audio output to the computer's mic in. This procedure worked before with Winows XP.I am getting the music to the computer but it is not recording. I have Audacity which is music editing software that is set up to work with the computer's internal recorder
    yes and thanks
    yes and thanks
  • 10,515 Answers
The problem concerned a lack of recording device within the operating system because the device was disabled by default.
Select : 'Start : Control Panel : Hardware and Sound : Sound'
The small 'Sound' window includes 'Playback', 'Record' and 'Sounds' tabs. Select the 'Record' tab.
Within the 'Record' tab, within the 'Select a recording device below to modify settings:' RIGHT-Click within this blank area and select 'Show Disabled Devices'
It is likely that the 'Stereo Mix' associated with the sound card is disabled. RIGHT-Click and select 'Enable'. While here, select the 'Properties' of the Stereo Mix' device.
Within the Properties there is likely to be a 'Levels' tab. Select this and ensure that the level is reasonable high - otherwise the recordings will be at a very low/quiet level.
OK this and return to Audacity. It should now record.
Other issues might be :-
I suspect that enabling the Stereo Mix feature of the sound card could cause problems with some of Vista's multimedia playing software. The intention of Vista is to stop users recording copyrighted materials! (And even if your use is legitimate, the secure pipe for media has been broken and might stop the media player working properly).
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 31, 2009
  • 1,555 Answers
Since your keyboard is not visible in the device manager or control panel that means you have not installed the correct drivers drivers for your keyboard. Below I'm providing the link from where you can download the latest driver for your keyboard kindly uninstall any drivers if you have installed earlier for your keyboard. disconnect your keyboard from pc before installing the drivers. connect only after installation or if asked by installation. In case you get any error just comment back. First check wether your OS is 32 bit or 64 bit then only choose the correct driver.
http://www.global.yamaha.com/download/usb_midi/index.html
I'm using vista home premium os, however the problem I enccounter is once you install software which is compatible for windows NT, xp home and windows 2000, the software the one I installed is not properly...
Yes, if you use a Virtual Machine, you can install the version of windows you wish to work with, install the software, and it should work just fine.
You will however need a genuine copy of windows to install in the virtual machine.
You may be able to find an image of the OS you need, or a snapshot of an OS, to load into the VM, it all depends on the type of VM you are going to use
Sep 30, 2010 | Microsoft Windows Vista Home Premium with...
No audio out-put is installed
maybe your problem is not on vista installer..
you need a audio driver..
if you are in a built audio card motherboard, you need the driver of your motherboard...
and reinstall your audio..
Feb 06, 2010 | Microsoft Windows Vista Home Premium with...
Problems to make the sony icd-sx25 software editor recognize my hardware when i connect to pc with usb cable. using a windows vista home premium 64 bit operating system
There is Sony Digital Voice Editor Version 3.2.01 available to work on Windows Vista Home Premium 64-bit.
Click Sony Support to download "DVESetup_EN_3201" file (size approx 83MB) and install it in your computer, this will solve your problem of ICD-SX25
Thanks.
Jan 29, 2010 | Sony ICD-SX25 Handheld Digital Transcriber...
How do I install windows vista home premium on a new blank hard d
first insert vista bootable dvd in dvd drive and then press any key to install windows and follows option
Oct 08, 2009 | Microsoft Windows Vista Home Premium with...
I need to transfer files from anexternal hardrive tomy computer. The external hardrive is connected to my computer but is not showing up.I bought a casr for an internal hardrive that I had removed. I have...
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Jul 23, 2009 | Computers & Internet
Restore Hardrive to Factory Settings, Missing Hidden Partition
Yes Claudia you are right. When you wiped the hard drive you deleted the partition that contained the systen restore (factory restore). You will have to purchase a new copy of Vista. It will not contain all of the other programs that came with your computer originally.
Before you installed Windows 7 it clearly states that you have to back up your system before you install it on your hard drive.
Why didn,t you keeep windows 7, if I may ask? If you made a copy of it (which you had to do when you insatlled it) reinstall it and use it. Microsoft will let you purchase it for $50.00, which is a lot less that what it will cost you to purcase Vista Home Premium.
Apr 20, 2009 | Computers & Internet
How to upgrade from Vista Basic to Vista Premium.
You need a Vista premium disk to upgrade to Vista premium.
Just instert the Vista premium disk and start the installation.
If installation does not start, you will need to boot from setup CD, sometimes you have to change the bios boot sequence in bios settings, to start the installation from CD.
Nov 16, 2008 | Microsoft Windows Vista Home Premium with...
Cannot load "arthur" with widows vista home premium stops installing
Hello... Please go thru this. Souce:http://www.ataricommunity.com/forums/showthread.php?t=573497
I may have a work around
It is a way to give admin privs to the msi file
First, create a file called Arthur.bat
- Open a folder, say C:\temp
- Right-click and select new, Text Document
- name it Arthur.bat
Next, edit the file
- right click the file and select edit
- put this in the editor ... msiexec /a d:\Arthur.msi
- save and exit
Then, right-click the file and select "Run as administrator"
Worked for me.
There is another msi file (ISScript11.msi) on the CD which I didn't run which may be needed ? But, I managed to play through the tutorial/start so ... we w ill see.
So, it is a permissions thing. Hopefully this will get passed on to the developers and they can resolve it tout-de-suite
Nov 02, 2008 | Atari Arthur & the Invisibles for Windows
Driver for windows vista home premium
I have Windows Vista Home Premium. I do not have my original Olympus disc. I downloaded the driver from driver guide (http://members.driverguide.com/driver/detail.php?driverid=583812) > installed driver (in this case pencam.exe. After installing the Olympus software I hooked the USB cable up, turned on my w-10 recorder and let Windows begin it's search.
I manually pointed it to the pencam folder where it proceeded to load the drivers successfully. I am now able to transfer my files successfully. Hope this helps in some way.
Oct 17, 2007 | Olympus W-10 Digital Voice Recorder
Computers & Internet Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
