Question about Garden
John deere F25 mower transmission locked up won't move. kills engine when forward or reverse levers are engaged.
  • 479 Answers
SOURCE: John Deere LT190 Lawn Tractor transmission problem
try to service the old transmisson it may work.but if that does not work just replace the transmisson.
purchasing a new hydrostatic transmission is much advisable as its definately the problem of hydrostatic transmission with out any doubt .but i hope servicing the old works.
Posted on Oct 01, 2008
  • 11 Answers
SOURCE: John Deere LT 133. Will not move with mower in gear and clutch/brake released. A smell like hot rubber prior. Mower will engage. Thanks.
It could be that the belt jumped off the pulleys and got caught between a pulley and a belt guide,or the trans-axel seized up ,or brake was stuck while in a high gear,and burned up the belt. most likely the first reason. if it wasn't for the burning rubber smell,I would also look for a broken clutch/brake return spring .The pedal would stay down with a broken spring
Posted on May 24, 2009
  • 3 Answers
SOURCE: john deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
Posted on May 26, 2009
  • 5 Answers
SOURCE: John Deere LA110 mower blades got disengaged
does it engage manually with a lever, or is it electronic with a push pull switch? if electronic, check the wire that goes to the electric clutch, it might have come off when unplugging it. do all this with the engine off
Posted on Jun 27, 2009
  • 61 Answers
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
Posted on Sep 07, 2009
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
Why will my Gx325 John Deere not go in forward or reverse
For a more precise answer give the Year/Hours on Meter, and a brief description of the events prior to the problem. When did it last run correctly? What has happened since then?
The first questions that comes to mind...
  1. Can you manually push the mower around?Easily?
  2. We need to know if the brakes are locked up?
  3. We need to know if the transmission bypass lever is in or out?
  4. With the bypass lever out, brakes off, can you roll the machine?
  5. Is the bypass lever still properly connected and unbent?
  6. Looking under the machine (right in the center above the cutting head) are the drive belts intact?
  7. Do the drive belt idler pulleys/bearing look ok?
  8. Is the drive belt engagement plate still connected to the foot pedals?
  9. Does the pulley wheel and fan on the transmission spin when the motor is running? (is power going to the transmission?)
These are your first things to check. You may have to remove the cutting head to fully examine these things.
Mar 10, 2015 | John Deere Garden
My john deere la 105 will not go forward or reverse, what's wrong?
Check your transmission belt from engine to rear diff. Up high above the deck belt. Its either broken or off its pulleys possible
Sep 24, 2014 | John Deere Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
My Lt155 ride on wont engage in forward or reverse
(Simple answer)Hydrostatic drive machines have a setting that allows you to push them. machine won`t move if this is engaged.
Also If park brake is on. Otherwise check drive belt has not snapped is loose or broken. Jack machine up and see if wheels will drive without weight of machine.
Jul 26, 2014 | John Deere Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
The rear end on my 1987 750 4wd john deere quit working yesterday, it will still go forward when i step on the lever to engage and lock both back tires but will not move unless i do, front end works fine,...
Check first to see if the drive belt has jumped off a pulley or the belt is stretched or broken. Next if there is a grinding noise it means the transmission has a broken or chewed up gear.
Jun 24, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
