How many HOSTFS can you put on a Sub mask of 255.255.255.192 ?
  • brianemer782 Jul 31, 2009
    How did you determine that 64 is the amount of HOSTFS that can be put on a sub mask of 255.255.255.192 ? Are there any bandwidth issues when streaming files for HDTV over a Intranet?
    President:
  • 627 Answers
For mask of 255.255.255.192 is 64
Posted on Jul 31, 2009
  • Robert Nyilas
    Robert Nyilas Aug 01, 2009
    for mask 255.255.255.0 is 256 - 0 = 256
    for mask 255.255.255.254 is 256 - 254 = 2
    for mask 255.255.255.252 is 4
    over intranet the bandwith is network card bandwith
    if you have 100 Mb/s the bandwith is 100/8 = 12,5 MB /s minus upload which is 25% of download
    I forgot to tell you that for 192 subnet mask which logically is 64 you must substract 2 because one is the gateway and the other is your computer ip
    So for 192 which normal should be 64 is 62 (1 gateway 1 your computer)
    If i wasn't so clear you can read more from here:
Hi...getting "LOCAL IP ADDR INVALID" on one of my INTER-TEL PHONES....82622V2
Bill
what about the sub net mask is it exactly the same as the others ?
Has the subnet mask been used to create a separate network ?
what is the subnet mask ?
is it 255.255.255.0
does it have numbers in it that are not 255 or 0 ?
if the number is different to this you have subnetting on your network and may need to use a particlar ip address to fit into the subnet.
Oct 18, 2016 | Computers & Internet
How do I open the subwoofer for LG HT762TZ-ZA; it has just stopped working
General:U may have turn it off/mute by remote accidentaly.ceck audio settings on the amplifier.Ceck on/off /volume button also located on the sub if apply.Ceck signal from the wiring with another woofer or multimeter (empiric u can do it by small light bulb 6-12v).If still need to open the case,remove the drive mask (textil/metal)by putting little pressure with a flat tool under it,under it should be the screws from the drive itself,can be taped with small caps.The box itself most likely it won't open.Caution:turn off ,work carefully not to scratch,use plastic tools,don't put large amount of pressure,the drive mask should pop easy.
Oct 21, 2013 | Subwoofer Box Single Vented 10" Fits Dodge...
I need the Konica Minolta Di470 ip address to connect the pc to print documents etc.
The ip address is provided by your it department if you do not have an it department then you can select an ip address that is not being uesd example 192.168.1.200 this lus the sub net mask standard sub net mask 255.255.255.0 needs to be put in the network section of the machine then you can go to the c: prompt on your computer type in ping then the ip address you put into the machine you should get 4 replys and no drops then you will also need to load the print driver for the machine onto your computer
Jan 11, 2011 | Konica Minolta Di1610 Copier
How do i establish a subnet with a B address
Subnet mask for 86 PCs is more than 64 and less than 128. it means that subnet mask is 255.255.255.128
You can have PC IP address in range 172.31.0.129 - 172.31.0.254
Apr 21, 2010 | Computers & Internet
Check IP adress, Sub-net Mask and Gateway adress
open rum command and type command ......
after open command prompt ....
type ipconfig and enter......
ok
you see your ip address subnet...
Sep 02, 2009 | Linksys WCG200 Wireless Router
To answer your question with regard to the subnet mask, here is a great reference. http://en.wikipedia.org/wiki/Subnetwork
The only limit on an intranet would be the bandwidth of your medium, if you have 100MHZ CAT5 ethernet should have not problems.
Good Luck.
Aug 01, 2009 | Computers & Internet
Can i purchase cressi matrix lower frame broken last trip
A broken frame on a nice mask, that is a bummer. I am only aware of replacement lenses, but not replacement frames. If you want to save on costs, you can find a used similar mask or a mask that uses the same style of lens that is interchangeable with your current model. I suggest looking on ebay, craigs list, and of course the internet.
Jul 15, 2009 | Seal Cressi Sub Matrix Gamma Two Window...
Asus wl-500w and modem
your sub net mask is wrong you have to put 255.255.255.0 and make 192.168.1.1 to modem and 192.168.2.1 to router
Apr 11, 2009 | ASUS WL-500W Router (WL500W)
Fax
Keep pressing function key
May 17, 2007 | Panasonic PanaFax UF-8000 Laser Fax
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
