Question about Philips 50PF9630A 50 in. Plasma Television
Polaroid pla-4248 red color only in right lower side of screen, found 14 amp fuse blown on panel on right side,did not solve the problem
    Problem Solver:
  • 15 Answers
Looks like Y-Sustain board fails .First of all there is no 14 A.fuse used on this tv. and replase with the same Amperace.If you use bigger Amp, it could damage the power board
Posted on Aug 01, 2009
Have a 42in polaroid hdtv... half the screen is colored lines butb the other hjalf is fine with good sound & pic
Usually a board---different names for each brand: Sustain, Y, Z etc.
Some sets (sound like yours) use one to drive right side of picture and another for left side.
The only bad news is Polaroid parts may be difficult if not impossible to find.
Mar 14, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
No picture. I have sound but just a black screen on all inputs. I even show the polaroid brand name when first turning on.
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hoping this will help in solving the problem...
Aug 06, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
2004 z71 180000 miles. drove from VA to TX. Headlights started dimming, battery not charging indicator came on. Battery charging level is not in the red but on the lower side (9-14-19) showing inbetween 9...
if battery and alternator are good. i would check the wire from alternator to battery, they sometimes have a fusable link in the wire, that burns out. also check fuse box there may be a fuse and it may be blown! at battery with car running should be at least, 14 to 14.2. at battery when car is off should be about 12.8 to 13 volts. have a good day !!
Nov 26, 2010 | 2004 Chevrolet Suburban
When i turn my polaroid pla 4248 on the light goes from red to blue and i get sound but no picture
The problem here is either a combination of what they call the X-sus printed circuit board and the Y-sus printed circuit board or a case of either one or the other, i reccomend that if you have a muti meter and the unit is well out of warranty, open the back of it, and test the voltages, which should be marked on the printed circuit boards where the plugs plug in from , or too , the main printed circuit board.
You will be able to find the Y-sus and the X-sus printed circuit board fairly easily as they should be marled with a part number and description, eg, Y-sus, etc, if not, they are the large printed circuit boards on the left and right side of the main printed circuit board.
If you find the voltages are different to that show on the circuit board by a large amount, chances are that printed circuit board is faulty.
I hope this offers some assistance. Good luck.
Apr 17, 2010 | Polaroid PLA-4248 42 in. Plasma HDTV
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Fuse for the radio on a 2001 Ford Taurus
do you have a owners manual? this will show the location and the purpose of each fuse and relay. the radio fuse should be red in color and be located in the fuse panel on the drivers side it is a 15 amp and is red in color... hope this helps you...please rate this thanks
Sep 02, 2008 | 2001 Ford Taurus
Polaroid FLM 2011
have a tech repair your tv the problem is in the power supply and related circuit.good luck.
Apr 12, 2007 | Polaroid FLM-2011 Television
Open Questions:
Philips 50PF9630A 50 in. Plasma Television Logo
164 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
