Question about Canon Pixma iP2600 Photo InkJet Printer
Couldn't install ink cartridge
I just bought a canon pixma pg-30 ink cartridge for this printer (pixma ip2600) but I just couldnt' put it in! It doesn't seem to fit though when I bought it, the website says that the cartridge could be used for this printer. Please help! Thanks
    Problem Solver:
  • 5 Answers
Well if its to big or small you should get a bigger or smaaler carton or you can check the hand book with the printer it came with(i think) or go to the link below
help on changing ink cartons for printers
Posted on Jul 31, 2009
Canon iP2600 Printer yellow light flaxes message says an ink cartridge is not installed properly
have you tried cleaning the printheads ?
There is an option for cleaning head in printer's properties : select this and you will be able to clean printehads for the canon iP2600
Jan 19, 2012 | Canon Pixma iP2600 Photo InkJet Printer
My canon pixma iP 1800 does not recognise refilled colour cartridge. Can you suggest a fix?
  1. For the not-so-tech friendly, installing ink cartridges in printers can be messy and time-consuming. Although companies such as Canon are constantly trying to make designs more convenient for all users, there are still several tips that can help new printer owners install Canon PG-40 printer cartridges without mess or hassle.
  2. Compatibility
  3. Although many printer cartridges are specific to only a few models, the Canon PG-40 printer cartridge was designed for use with many models of the Canon Pixma and even some of the Canon fax machines. As of September 2010, the Canon PG-40 ink cartridge can be used with the Pixma iP1600 through iP1800 printers, the iP2600 printer, the MP140 through MP190 printers, the MP210 printer, the MP460 and 470 printers, the MX300 and MX310 printers and the JX200 and JX210P fax machines. This versatility allows users to stick with the same type of ink cartridge over the life of several printers and allows small business offices an opportunity to buy one type of cartridge for all office printing requirements.
  4. Refill
  5. Replacing printer cartridges can be expensive and, if it is possible, as it is with the Canon PG-40, refilling is a cheaper and more environmentally friendly option. Refill the PG-40 by gathering a 10 cubic centimeter syringe with a 1.5-inch needle, a pair of latex free gloves, an MIS Yellow Drill Tool, Scotch tape and black ink. Remove the label from the top of the cartridge and use the yellow drill tool to open the vent hole that was covered by the label. Next, load the syringe with 20 CCs of black ink and inject it into the ink hole (where ink leaves the cartridge for the page.) Make sure the needle reaches the bottom of the ink tank and then slowly inject the ink into the cartridge, stopping when the ink begins to well up at the needle insertion point. Now remove the needle and clean the top of the cartridge off to avoid color contamination. Put a small strip of Scotch tape over the vent hole and poke a small hole in the tape with a pin. Now reinsert the cartridge and run up to three cleaning cycles to calibrate the printer.
  6. Resetting the Ink Level
  7. While refilling ink in a PG-40 can save money, it can also cause difficulties when using the automatic ink level sensor. Reset this sensor by removing the cartridge after the printer has been calibrated and placing a thin strip of Scotch tape on the line of gold-colored leads nearest the ink hole on the bottom of the ink cartridge. Replace the cartridge and wait for the computer to display a warning about the ink cartridge being loaded incorrectly. Remove the cartridge and move the tape from the first to the second level of leads and replace the cartridge. When the PC displays a message that the cartridge is not recognized, remove the cartridge and replace without the tape. The ink level will be reset.
Jan 09, 2011 | Office Equipment & Supplies
Please how can i refill a canon printer's cartridge (canon pixma ip2600), without the ink pouring out through the other end
Place the empty PG-30 cartridge on a layer of paper towels on a flat surface.
Use the thumb screwdriver to enlarge the small refill hole just below the letter "B" on the top of the cartridge.
Fill the syringe with 20 ml. of black printer ink.
Slowly insert the syringe into the refill hole that you drilled and release the contents of the syringe.
5
Allow the cartridge to sit upright for 4 hours before inserting into the printer.
Easy!
~KenjiFox
Jan 07, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Canon Pixma MP210 will not recognize high yield PG-50 & CL-51 cartridges.
The canon pixma mp 210 uses PG-30, CL-31, PG-40, CL-41
It will not recognized the PG-50 & CL- 51
See if you can return it and exchange it for the PG-40 & CL-41.
If not, the only other way is to transfer the ink into the other ink cartridges.
The cartridge cap can be removed by a sharp tap at the back end of the cover.
You can glue back the cover.
If there is an E 1,6 Error code, Ink has run out after you install your ink cartridges
Press and hold the stop/reset button for about 10 seconds to clear the error code.
Dec 24, 2010 | Canon Office Equipment & Supplies
I am trying to put a new ink cartridge into my iP 2600 printer.
http://www.youtube.com/watch?v=JVt2InySn2Q
follow this link, it is a video from you tube on how to install ink cartridge in canon pixma ip2600
Dec 04, 2010 | Canon Pixma iP2600 Photo InkJet Printer
New ink cartridge not recognized
Please check if there is not some dirt, or something blocking the contacts from reading. Also the ink level is measured by optical sensor that can also be dirty.
Also make sure you use an Original Canon cartridge.
Feb 28, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Is MP210 and MP240 the same? can i use the same cartridge?
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
How do I insert the refill ink cartridge?
according to all information i can find you have got the correct cartridges
nip to canon.com and download the user guide that shows you how yo install your cartriges
Regards AL "alstech"
May 25, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink cartage
This printer will take either the PG-30 or PG-40 (larger size) cartridges for black ink, and either the CL-31 or CL-41 (larger size) cartridges for color ink.
Jul 26, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
285 people viewed this question
old marine
old marine
