Question about Garden
Chainsaw bogs down/out when throttle depressed
I have a Husqvarna Rancher 55. It is less than 3 years old. When it gets warmed up it bogs down when you depress the throttle and will not increase in RPM. No RPM, no cut wood. I had a smaller chain saw a couple of years ago that had the same problem and I never could find out what was wrong with it. Could this be a gas mix problem?
    Problem Solver:
  • 6 Answers
Not if you''re certain about the mix you've created. Also, I presume the plug is not fouling and you've got the choke issue handled. One thought is that the fuel is old and sort of turning to varnish (hi/lo temps) Also, check the internal fuel filter - it's a little membrane that's somewhat hard to handle. Also, if the problem is a real gremlin it may just mean a tune-up at your local shop for a nominal fee
Posted on Jul 31, 2009
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Rancher 455 wont stay running
you need too adjust the high jet ccw (making it richer) do do that takes
a little work cause you need a special tool but I can help you around that if you like. let me know
Jul 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a Rancher 55 18" with a new chain. Started
First thing you need to check is the cylinder.Take the spark plug ouy.use a flashlight and look down the hole towards the muffler side.If its scratched up afraid the motor is shot and will need to be rebuilt.If its not scratched up let me know on here.Then I will give you more things to check.
Mar 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a rancher 55 and I had to reconnect the gas line to the carburator and now I can't reconnect the throttle I need a view of the throttle assembley. Where can I find one thank you
55 IPLs start at page 4 but I doubt it has the level of detail you need.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I suggest you go here and join.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
The following thread is about your saw. Someone of will probably be willing to provide the photo you need. There are other threads where your saw is discussed.
http://www.arboristsite.com/showthread.php?t=122545&highlight=55+rancher
I must warn you. Many that frequent here develop an obsession with chainsaws. When I joined I had 1 and had only owned 2. I now own 7 and am always on the look out for a new one.
Good luck with your project. HTH
Lou
Feb 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Looking for proper h/l jet settings on my husqvarna 266 se chainsaw..or a manual i can download ...i found one...but it was in swedish
rule of thumb is 1 torn out from closed will get you started. then run at high speed and richen the H screw till you hear it just starting to bogg down every few seconds. Then let off the throttle and adjust the L screw till it runs smooth the richen it a quarter turn. Thats the old fashioned way I have been using for 40 years
Nov 18, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I need to know the right angle to sharpen my chainsaw
If your saw still has the original bar and chain, it was supplied with a .325" pitch chain and you'll need a 3/8" round file with a sharpening guide to properly sharpen it.
Here's a link to the Husqvarna site to the Rancher 455 models so you can select the correct manual to download, that matches your particular saw, based on the year of manufacture, etc.
There is some excellent information about maintaining your saw, along with a really good guide with step-by-step instructions for proper sharpening.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=455&types=O
If you're having trouble figuring out the right manual for your saw, use the online Customer Support page and they'll reply.
Hope you find this Very Helpful - Best regards!
Aug 19, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
597 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
