The water keeps running in and overflowing. The short hose behind the water level knob is connected one end only but can't see a place for the open end.
  • jock899 Aug 05, 2009
    Yes, very helpful. Thanks.
    President:
  • 1,776 Answers
This problem is usually caused by a faulty water level switch. The switch is a diaphragm like device with a small clear plastic tube between the switch and the bottom of the washer's outer tub. As the water level rises, the pressure increases on the air in the tube. When the pressure reaches a certain level, it activates the switch to shut off the water and signals the timer to agitate. Look for any obstruction in the tube and clean out if you find any. The switch can be tested using a multimeter or ohm meter to check for continuity. If the switch has no continuity, it is bad and will need replaced. Hope this helped and best wishes.
Posted on Jul 31, 2009
In rinse water does't shut off. Just keeps running and overflowing.
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 14, 2010 | Washing Machines
Tip
Washer Overflows
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
on Dec 04, 2009 | Washing Machines
Tip
Washer Overflows
on Jul 09, 2008 | Kenmore 24032\24036 Top Load Washer
The water overflows the tub during the rinse cycle when the water level is set for large loads
Sep 06, 2009 | Kenmore Washing Machines
Overflowing washer
Jul 27, 2009 | Kenmore Washing Machines
Kenmore 90 series- The water will not stop when I
Jun 29, 2009 | Kenmore 22422 Top Load Washer
Rinse water doesn't stop filling on large load setting
Mar 11, 2009 | Washing Machines
I have a Kenmore portable washing machine model number 1102970090. when filling the machine no matter what water level is set it won't stop filling and overflows.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Mar 06, 2009 | Kenmore Washing Machines
Hoover commodore Washing Machine Overfilling
Jan 21, 2009 | Washing Machines
Have maytag washer will not stop filling at medium or small level can hear it click and still keeps running
Jan 01, 2009 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
