Question about Polaroid Televison & Video
Had a storm and the tv is out 4011TLXB 40" widescreen LCD. Everything else in the house works and the electricity was not out.Is there a reset?Or what else could it be?
    President:
  • Polaroid Master
  • 1,779 Answers
Almost anything could be an issue. The best advice is to take it into a service center to have it looked at.
Posted on Jul 31, 2009
Closed caption is on and neither the remote nor the menu setup options for cc are working. I tried resetting to factory settings but no help. Advice?
Search Results
    [PDF]Instruction Manual
    static.bhphotovideo.com/lit_files/62319.pdf
    TFTV1525 ... If this equipment does cause harmful interference to radio or televisionreception, ... The LCD panel used in this television contains millions of thin film transistors that ... 15. or cable system during a lightning storm or when it is left unattended and ..... There are four options lised under the Closed Caption menu.
    COBY TFTV1525 INSTRUCTION MANUAL Pdf Download.
    www.manualslib.com > ... > Coby Manuals > Flat Panel TV > TFTV1525
    COBY Electronics TFT LCD Widescreen Television Instruction Manual. ... Cobyelectronics 15" widescreen lcd hdtv/monitor specification sheet (1 page) ... Operation is subject to the following two conditions: • This device may not cause .... Direction &OK While working with the system menu, press the direction buttons to ..
Jan 13, 2016 | Coby TFTV1525 15 in. LCD TV
My Humax HDR will not output in widescreen display format! Worked perfectly before!
That is what always happens when something breaks... It would help if you had more info like was there a electrical storm, does everything else work, do the lights light up... I will say this; Most electrical appliance failures are due to no power. As in the switch in the surge protector was turned off when vacuuming the area, etc. So, check all the connections to the wall and then if these are good, by good I mean you replaced them with known working extensions and check the little ground fault button in every outlet too... then get back with more info.
Oct 09, 2014 | Humax Hdr-Fox T2 500Gb Freeview Hd Digital...
My hdmi input wont work after a storm
it could be a number of reasons goto a tv repair shop most likley a fuse blew...
Jun 30, 2012 | Westinghouse 32 LD-3265 720p Widescreen...
Sanyo Dp42841 no power
More than likely your power supply board is damaged. The scary thing about TV's that get damaged as a result of T-storms is that multiple boards can get damaged. I would suggest taking it to get it diagnosed properly instead of the 'guessing game". That game could cost you more in the long run.
May 27, 2012 | Sanyo 42 in. LCD TV
40''polaroid lcd(4011TLXB) has power to it but no pcture or sound? whats difference from power supply board and main control board
Power supply module is to supply voltages to the main control board (the board where the TV cable and video cables are connected to), backlight inverter board. You can buy the whole control box which has both board assembly (power supply and the main control board): http://www.shopjimmy.com/catalogsearch/result/index/?q=Polaroid+4011-TLXB+&limit=25
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 25, 2010 | Polaroid 4011-TLXB LCD TV
I have a 2008 Toshiba tv 40RV525U model. We had a thunder/lightening storm. The power to the whole house did a on/off/on flicker. Now my tv only has a flashing power light (green). Does this mean my tv is...
The power source of the tv has been fried by the power surge and it must be replaced, the damage is surely to great to fix it. Pray to all your gods that the damage is limited only to the power source, otherwise the tv is truly dead.
Call a tv repairman, there's nothing more you can do.
And next time when you have a storm unplug everything with electronics in the house, from every wire.
Jul 19, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Sony bravia kdl40S504 has green ghosts - cannot
I do not think that cause by power surge, and it is on manufactory warranty, you better to call Sony.
Jun 26, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Polaroid 4011tlxb,wont turn on,red led
take the back off and look on PCB you should see a couple of 1000 uf caps bulged up and change them out.
Mar 11, 2008 | Televison & Video
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
