Question about Canon PIXMA iP1500 InkJet Photo Printer
When i try to print i get(head not installed)
Hello, when i try to print i get ( print head not installed)
    President:
  • 2,306 Answers
That is either a defective printhead, or bad main logic board, most often it's just a bad printhead.
Posted on Aug 05, 2009
  • Craig Gillette
    Craig Gillette Aug 07, 2009
    How can elig1000 be soo stupid, and offer advice to others?
  • 108 Answers
Check to see if the printer cartrdige is moving along the carriage.
Posted on Jul 31, 2009
I have an ESP2150 with an error message of printhead loose or missing. I checked print cartridges, I replaced print cartridges, I re-installed software and drivers.....I still receive the same error...
Unfortunately, trying to diagnose a printer without actually looking at the printer is a little like trying to diagnose a car engine over the phone. But, from the sound of it, the problem you are having is not exactly pertaining to the print "cartridges" but the print "head" which is the part of the printer that actually introduces the ink to the paper, and is actually part of the tray the ink cartridges fit into. Here is a picture of it:
This print head is able to be removed and replaced if needed. It may be something as trivial as being loose. You can remove it from the printer and reinstall it to make sure it is seated correctly. Here is a link for instructions on Kodak's website on how to uninstall and replace the print head:
Installing and replacing print head.
If the print head is either damaged or worn out (which can happen) you can replace the print head, which I just did a search online for one and it appears the print head is only around $35.00 to replace it. Here is a link to where I found a replacement print head:
Kodak Print Head Replacement for ESP2150
I hope this helps.
-Nathan
Sep 26, 2013 | Kodak ESP Office 2150 All-in-one Printer
Error 1403
hello this error means that the EEPROM data of the print head is faulty so is a problem with the print head,
Install the print head properly,and close the access cover. Or, with the print head installed, turn the printer off and on, i hope it will help And please check the below link to get the service manual for ip4000 it will be helpful:
http://goo.gl/Edjmh
Good luck.
Jul 21, 2013 | Canon PIXMA iP4000 InkJet Photo Printer
Have error message UO52 print head is incorrect, have installed correct ink cartridges what do I do ?
It could in fact be a defective print head problem but try cleaning it first:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Jul 07, 2011 | Canon PIXMA MP810 All-In-One InkJet...
When making On, the printer displays a message W7100
this error code, stand for print head trouble.
You can try following:
1. Visual inspection:
Press down the BJ print head set locking lever to set it in a proper position if the
lever is pulled up.
Install the BJ print head if it is not installed.
2. Carriage unit
Visually check and replace faulty BJ print head set components or BJ print head
locking lever.
3. Replace the head controller.
4. Replace the system controller.
Hope that helps!
May 30, 2011 | Canon BJ-W9000 Copier
Hello, To whom it may concern, I just bought a refurbished Canon Pixma MX700 from Overstock.com and I set it up according to the instructions and it does not print much at all. I have run all of the...
Make sure you have the latest drivers for the printer installed on your computer by visiting the manufacturer's website and getting and installing the latest version. Next, if you've already run the cleaning procedure, try replacing the ink cartridges. Finally, if that doesn't work, the printer may be defective and should be sent back.
Mar 18, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Poor print quality, was OK but colors are very faint on the paper, everything checks out OK in the maintenance programs.
Hello there:
this is normally due to a dirty print head or the nozzles is clogging up
If you have ran your maintenance for the print heads and cartridges several times at least 4 in a row and this still does not clear up and you have tried to get new ink cartridges.
Go to your local printer supply center like office depot or staples and get the print head flush kit this is a specially formulated liquid that you install and it flushes out the print heads and gets all of the ink that has built up in the system out and gets the print heads cleaned it cost about 6 bucks but well worth it
Hope this is very helpful for you
Best regards Mike
Jan 19, 2010 | Dell 1320c Laser Printer
Hello! I don't use my Epson PictureMate as often
That is a problem with the Ink jet printers. Lack of use causes the cartridges/heads, etc. to dry up. You're only solution (I'm afraid) is to replace them.
TIP: If you're typically not using the printer for several days or even week(s) at a time, it never hurts to print a single (low coverage) page of colour every few days just to keep the ink flowing
Jul 10, 2009 | Epson PictureMate C11C623001 Photo Printer
Print Head install
Hello Dear,
The Print Head in your printer is physically damaged and so even though it is present and installed it will not be detected by the Printer, you need to purchase and install a new print head for your printer.
Warm Regards,
Manoj Joseph
+91 9352008418
Jun 17, 2008 | Canon PIXMA MP470 All-in-One Printer
"PUT IN CARTRIDGE" error with cartridges installed
Hello Dear,
Warm Regards,
Manoj Joseph
+91 9352008418
Mar 15, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Canon PIXMA iP1500 InkJet Photo Printer Logo
151 people viewed this question
old marine
old marine
