About every twenty loads when I wash a load it will go to F-28 and not finish the load of laundry. Within the first year I had the repaiman out for noise, vibration and this problem and they couldn't find anything. I am getting very upset. I Have always used Seaars produscts but this washer has left a sour taste in my mouth. HELP!!!
  • wemajwb Jul 31, 2009
    Can a person with little experence be able to do your solution?
  • Washing Mach... Master
  • 2,200 Answers
F28 is a SERIAL COMMUNICATION ERROR.
Given the intermittent nature of the problem it is highly possible that this error is caused by a loose connection on the serial wiring of the machine. You can check these connections over yourself.
There are other possible causes however and I have listed what the technical repair manual says about it below.
F-28 SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
– Check connections of the CCU board within the housing.
– Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
Hope this helps. Please do remember to rate my answer. Many Thanks.
Posted on Jul 31, 2009
  • Radio Code Pro
    Radio Code Pro Aug 01, 2009
    Hi
    Some of these are ideally a job for a technician who has experience to spot wear on drive components etc...
    However the wiring connections can be checked by any person to make sure the connectors are tight and have not loosened. Given the intermittent nature of your fault it would certainly be worth your while to check any connectors that you can easily access as that alone may just resolve your problem.
    If you feel comfortable enough removing some panels to inspect the connections there is no reason why you should not do this yourself. Even if you are unsure what connectors you are checking - just check them all to see they are well pushed in and secure - you can do no harm by doing this.
    If you feel happier getting the tech to do it - give him the whole list to go through - at least then you know that has been done.
    Just be sure the machine is unplugged from the mains supply when you do this!
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Loads all of a sudden are unbalanced
look at supports and levelers for out of adjustment or damage
Jun 02, 2017 | GE WSLS1100A Top Load Washer
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
Failure Code of F-28 and the door is stuck
F-28 refers to a sensor that has gone bad.
You will need to call a service repair man.
John
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader locks, but nothing else. Please help!
ck to see if water still in tub if so remove as much as possible then remove bottom cover and clean pump..if you are washing baby clothes use mesh laundry bag for small items such as socks they tend to plug up pumps easily
Nov 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Hoover ultra care 1500 large load machine CYCLE IS TAKING HOURS TO FINISH
Hi Frank,
Went through this a couple of time.  Two things, at different times.  First is it draining?  If it is, then check the motot brushes.  They cost about £25 and take twenty minutes to replace.  Mine failed at three years.
If it's not draining, then their is probably a blockage at the drain pump.  Anything bigger than twenty pence coin could do it.  Again, easy to do, just do it outside near a drain.
Neil
Nov 01, 2008 | Hoover UltraCare HC6 150M Front Load...
LG front load washing machine will not spin
I am having the same problem with my washer. Go to this web site below it has a free troubleshooting guide. I narrowed my washer machine down to two parts. Stator assy or Main PWB assy.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
Oct 10, 2008 | LG WM-1832C Front Load Washer
Kenmore 80 series heavy duty super capacity washer-new in 2002
HI colleen. thanks for the question. i know that you have been doing laundry for 30 yrs. i have been repairing for 45 years. they did not have daugs then. so the problem was not there. yes overloading is the cause . but if it wont go into the spin cycle . that could be the lid switch.
Oct 07, 2008 | Washing Machines
Won't spin.
Your washer obviously has been over-loaded. It trips the spin switch & prevents top-speed spinning. See that you load within the machine's user manual load, not more. You can even weigh your laundry before loading to see that you dont over-load. Also see that the laundry is evenly placed within the bucket. These are suggestions.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
