Question about Home
I have a leak around outside of the bowl which I suspect is due to a leak between the cistern and bowl/pan connection but can't figure out how to remove the cistern from the pan? There don't appear to be any cracks in the bowl externally or internally so I suspect the leak is between interfaces/connections. Could it be that the valves and flaps referred to in a previous listing need to be replaced?
  • Kenneth Reaume' May 11, 2010
    What is the make and model of the item in question? Thx
  • 117 Answers
You should have two bolts going through the tank connecting the tank to the bowl , inbetween those bolts is the pipe that the water flows through from your tank to your bowl , this pipe has a gasket on it. if the bolts are loose on the tank it will cause that gasket to leak, you have to take the bolts off and get a new tank to bowl gasket, any plumbing supply place should have some for you , you will want to get new tank to bowl bolts ang gaskets for that aswell or you will have problems with those leaking too when you put it all back together!
Posted on Aug 02, 2009
How does the cistern fit onto the toilet and connect to the water outlet. Does it got onto the toilet seat if so how do you connect the water supply?
normally the cistern is mounted to the wall and the pipe to the bowl (pan) is just connected by a rubber grommet at the pan inlet and a threaded nut that compresses a rubber ring in the cistern end
water supply is via a hose from the isolator tap next to the an up to the pipe under the cistern
Aug 26, 2017 | Home
Water found around the base of the toilet on the floor
run your fingers around the pipe from the cistern (tank) to where it goes into the pan( bowl)
there is arubber gasket( fitting there that perishes and leaks water every time the system is flushed
lfush the system and feel fro water leaks
new gaskets are available from any hardware /plumber shop
May 12, 2017 | Home
One of the tank bolts on our toiletleaks, but only when the tank is full. I have tried new washers, new washers with silicone, same result, only leaks when full. is there something else I can try
if it is a bolt that the cistern is using for mounting on the wall, lower the water level in the cistern as it is too full
the level should be around 1" lower that mounting holes or just below the overflow opening whether it be a pipe to the outside ordown the center of the flush tube into the pan
Dec 18, 2016 | Home
Cistern leaks into bowl
Depends on the country you live in, but in North America, you need a new Flapper in the bottom of the system. Cheap to buy and take 10 minutes to fit.
Pictures and video of them.
Cistern Google Search
Nov 07, 2016 | Home
Raising water level in toilet bowl Niagara Stealth
the water level in the pan is set by the exit pipe level and if it is raised it will only flow out again to that pipe level
if you are ferefing to the cistern water level
remove the top and adjust the float level or level control unit
Sep 10, 2016 | Niagara Stealth Ultra High-Efficiency -...
Water level in new toilet bowl to low
water level in the bowl( pan) is determined by the height of the sewerage pipe level that it is connected to and is fixed by design and style of the pan
unless you are on about the water level in the cistern( tank) which you can adjust yourself
Nov 17, 2015 | VitrA Aria Toilet with Elongated Bowl/...
How do we Stop leak down side into water in the bowl between flushes?
is it a close coupled toilet? as it sounds like you need to change the doughnut washer between the pan and the cistern.
Aug 30, 2014 | Home
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Opal 2000 toilet suite, water leaking from around bedding cement. Have marked water level in cistern and bowl with marker and there is no change, water would appear to be coming when toilet is flushed like...
check the donut seal which seals the cistern to the pan, they perish and leak when the toilet is flushed, water runs down back of pan to floor you can check this by drying/wiping with tissue back of pan and flushing you will see if any moisture is running down there by wiping again with tissue and seeing if it is damp.
Sep 04, 2011 | Caroma toilet - water saving Sydney Low...
How do i fix a cistern that is continually leaking in to the toilet bowl? i have tried to open the cistern at the flush button unit but do not want to force open. tried twisting but is quite tight.
most modern toilets do not have an overflow pipe to outside instead they overflow into the bowl itself so have to adjust level so it does not overflow into return
Apr 02, 2010 | Toto Aquia II Dual Flush Toilet
Home Logo
188 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
