RCA 52'' Television problem
I know nothing about televisions. So your talk of circuit boards and horizontal boards are a mistery. In laymans terms you you please describe why my television wont work. I press the power button on the television manually and the green light comes on but the television wont fire up. The green light eventually turns off after 6 seconds. Is there something wrong with my power supply?
  • 556 Answers
Probably, there is some capacitors on the board that sometimes go bad if thy look or is some cases you have to feel if they are poked up then that is why the tv won't come on. A capacitor is a round cylindrical part that stands up on the board, it is like a battery it charges and discharges and if it looses this capability then your tv will not come on. I hope this helps.
Posted on Aug 21, 2009
D52W19 how the replace flyback?
I cant post it here because its too long but send me a email request to slinteriors@yahoo.com for help with removing and replacing it correctly
Feb 11, 2013 | RCA D52W19 52" Rear Projection Television
Where can I get a defleciton board for my RCA D52W20B television?
yes thats the deflection board. www.tvrepairworld.com has the ITC222 deflection boards listed under the RCA Circuit boards catagory they have warranties on all their circuit boards and installation instructions are also provided.
Mar 02, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
Oct 16, 2009 | RCA P52926 52" Rear Projection Television
Still can,t find fuses in back amp 250v and 6.3
I have only found one fuse on this, but there's probably others. The one i found was to the left and behind the plug. you have to take off the black plastic covering the plug, and all the other connections. You can see the fuse if you look between the bottom of the vertical and horizontal circuit boards in the corner.
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Need circuit board
You might be able to get some help from the owner of the RCA name;   Thompson Consumer Electronics
Mar 01, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W20 tv
3 capacitors On Deflection board cp150 2200uf 16v see if it is puffed up on top if so it is bad also replace 2 more caps in same circuit cp114 cp120 both are 220uf 35v they are green with gold writing.For Parts 1-800-223-3205. www.electronix.com
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
Flyback board for RCAd52w20
a bad flyback will inhibit the protection circuit. This sounds like what's happening.
Aug 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted picture
The RCA P52960 uses the PTK195 series chassis. There are 2 main boards at the bottom of the set and above the board on the right (when viewed from behind) is the convergence power supply board. This board usually has a big black IC on it, labeled STK730-010 and bolted to a metal heat sink. Chances are, that IC has burned out and stopped working. Replacing that IC should restore your convergence. If you do not have experience replacing IC's in projection sets, allow a qualified tech to handle it for you.
Aug 29, 2007 | RCA P52960 52" Rear Projection Television
56" RCA projection TV
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
Jan 17, 2007 | RCA P52921 52" Rear Projection Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
