Question about Fuji FinePix S700 Digital Camera
The little door covering the memory card has broken. Can I get a replacement or do I need to take it somewhere to get it replaced?
  • 300 Answers
Hi!
I could sell you a new or used door. If you're interested, contact me at toms.safranovs@gmail.com
I need to know the model.
Tom
Posted on Jul 31, 2009
  • jodisweere Jul 01, 2011
    Does this offer still stand? I have a broken door on a FinePix S700
Nikon Memory card cover has broken and needs replacing
Try Teleplan Camera Repair (http://teleplancamerarepair.com)
They have parts and will have no problem getting you a replacement cover!
Apr 29, 2010 | Nikon D90 Digital Camera with 18-105mm...
The latch on the camera door is broken. Can it be replaced?
Sure.
Replacement covers on their own rarely surface on ebay, but you might be lucky and find a "donor" camera with a working cover - it will probably work out cheaper than trying to order directly from olympus or their parts department.
The battery cover is attached to the back cover of the camera, you'll need to unscrew it (make sure you take notes of which screws go where as they are not the same).
Hope this helps,
Good luck,
Raf
Nov 13, 2009 | Olympus 8.0MP Digital Camera Holiday Gift...
Every time i insert the memory card it eject it, it doesn't keep inside
This is a serious hardware problem, that Sony would have to fix, or they might replace your PSP. There is a locking mechanism on the inside of the Memory Stick slot tat is a little difficult to engage, but it's also possible that that has broken off, which would need either some epic jerry-rigging with the slot cover, or get it repaired by Sony.
Sep 24, 2009 | Sony PlayStation Portable (PSP) Console
The door to lockdown my memory card is broken what do i do ?
I've done some searching and all I could find is a replacement memory card door at bbrepairshop.com. It's fairly pricy, especially after shipping and handling charges are added, but, like I said, it's all I could find.
Dec 21, 2008 | RIM BlackBerry Pearl 8100
Broken memory card/battery door
I found this site with some replacement parts and battery doors looks the same. I dont know if is original. I also have the same problem. If any of you have found the part in a different web site.. just let me know please.
Jul 31, 2008 | Cameras
Memory Card Cover
Hey janest,
You can find a link below to the manufacturers parts department.
http://www.fujifilmusa.com/support/ServiceSupportPartsContent.do?prodcat=616757
Sincerely,
Allan
Go Ahead. Use Us.
May 15, 2008 | Fuji FinePix S7000 Digital Camera
Acer 5315-2713 add memory card
OK, In general for the 5315 series, the memory replacement should be roughly the same.
You seem to have an idea what you're doing, so here's a little specifics:
Here's what you see once you get the giant "thermal door" cover off. To remove the cover, first, remove the four screws. Now carefully slip a thin tool like a table knife under the edge of the cover where the indent is and work around towards the front and back of the laptop.
DON'T pry along the side towards the side of the laptop or you'll break those longer tabs. That's the edge which goes in first when you replace the cover.
The RAM pops out easily by spreading the clips on either side.
Apr 14, 2008 | Acer Aspire 5315 Notebook
Card cover open error, but I have pics on the camera!!
Look on ebay for a replacement door. shoundly be too expensive
Sep 25, 2007 | Olympus FE-130 Digital Camera
Replacement Battery Cover Assembly
If you're handy, you can replace it in about 3 minutes. Don't attempt it unless you're willing to risk tearing a thin flexible circuit under the rear cover. Looking at the camera from the rear, remove the screws on the right hand side ( 2 ? ) then the screws across the bottom - open the card door, remove the card, and wedge a knife blade between the front and rear cover halves - the card door will be loose with an attached spring coming free. No need to remove the rear housing completely, just enough to expose the tracks for the battery cover hinge. Remove the old door, noting the position of the opening spring at the hinge, by angling one hinge out first. Insert the new battery cover and the card door in reverse order.
Dec 05, 2006 | Kodak EasyShare CX7430 Digital Camera
My screen keep showing the Card Cover Open Error even though the cover is closed. What can i do
Somewhere on the door will be a small piece of plastic which when the door is closed makes contact with a microswitch which tells the camera the door is closed. Either this switch has broken or the piece of plastic has. Somewhere within the memory card receptacle you should find a small hole where the piece of plastic enters when the door is shut. Switch the camera on, leave the door open and push a wooden match or something of a suitable size made of plastic into this hole (be gentle) if the "door open" sign clears then the problem is with the prod built into the door. If it doesn't clear then the problem is with the switch. Actually this switch can be disabled or continually shorted out if it proves to be faulty. I have had a camera come in for an unrelated repair with the hole blocked up with plastacine to hold the swich closed. IT WORKED Stu
Jun 28, 2006 | Olympus Camedia C-4000 Zoom Digital Camera
Fuji FinePix S700 Digital Camera Logo
149 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
