Question about Sony Video Game Consoles & Games
Av cable how do you plug up the av cable to your tv
  • Sony Master
  • 2,404 Answers
Before plugging up any cables to your TV, look to make sure that you know the input number on the back of the tv if you have multiple inputs on your TV.
Make sure the video cable plugs into the video input on your tv, then the two audio cables, make sure they plug into the audio inputs on your tv and then make sure your tv is set to the right input and everything should be good, turn on the game system and enjoy.
Posted on Jul 31, 2009
How to hook up a vcr to tv?
depends on the cable you are using ?
if the cable has a yellow plug on it this is AV in and video
If Red and White plugs this in Audio in and should be with av in socket on back of TV
If cable was hdmi then hdmi in on back of tv
what was on the back of VCR AV out ?
HDMI out ?
Antenna out ?
Mar 19, 2016 | Westinghouse Televison & Video
Is HDMI4 correct or HDMI1?
how many jacks do you have . I would think it will be 1 or 2
Feb 22, 2016 | Dynex Televison & Video
How do i hook up a dvd player yo a 55" emerson flat screen tv
Use a n AV Cable, Yellow (Video) white (Audio) Red (Audio) and plug into DVD AV OUTPUT and plug into TV AV 1 or AV 2 Inputs and then select the AV Input you are using on your TV Via your TV Menu and you shall have sound and Picture.
Happy Movie entertainment.
Jul 31, 2014 | Televison & Video
Why won't my TV accept the Av signal from my VCR?
A couple of possibilities. First a faulty cable or socket on either the TV or VCR. Next the VCR is plugged into the wrong AV connection.
Jul 24, 2013 | Televison & Video
Wii does not show up on the tv screen
This problem is likely due to a problem with your AV cable. Try the steps below to get your Wii up and running.
  • Make sure the Wii is turned on and all cables are plugged in.
  • Unplug the AV cable from the T.V. (The AV cable has a red plug, a yellow plug, and a white plug.)
  • Plug the AV cable back into the television making sure that the red plug goes into the red socket, the yellow plug goes into the yellow socket, and the white plug goes into the white socket.
If problems continue try replacing your AV cable with a new one.
Jun 16, 2011 | Nintendo Wii Console
Doesnt show up on the television. It does turn on. turned playstation on and off, tried different connections, still nothing
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television. Follow these steps to get your PS3 up and running again
  1. Unplug your AV cable from your PS3 and T.V.
  2. Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
Jun 13, 2011 | Sony Playstation 3 (PS3) Console
I buy a ps2 please tell me how can i install it in my bravia lcd
The PS2 comes with an AV cable. (Red, White, & Yellow). Plug those cables into the matching slots on the back of your TV. They are color coded. If the TV is newer and does not have a spot for AV cables they you will need to by the HD cables or Component cables to match what your TV supports.
I don't know of newer TV's getting rid of AV links yet. Once they are plugged in, change the TV video input to the one that you plugged the cables in.
Mar 01, 2011 | Sony PlayStation 2 (PS2) Console
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
Powers on but won't feed through to the tv
you either have the wrong channel
if you have a tv make sure you have it set on tv if you have an hdtv set it on hdtv.
or the AV cable is not plugged into the right colors or you dont have the VIDEO cable plugged in
also ask a friend who has a ps3 to borrow there AV cable your AV cable might not work anymore.
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
Sound Problems
u need a new av cable some things just come already defected from the manufacture
Jun 06, 2009 | Video Game Consoles & Games
Video Game Consoles & Games Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
