Question about Bissell 9400 ProHeat Upright Wet/Dry Vacuum
Bissell Proheat 2 solution tank
I bought the machine Oct. 2007. The solution isn't emptying from the solution tank when I use my cleaner. I called the Bissell service number for help and they had me try these things: 1-When depressed, solution does come out of the x-valve on the cap of the solution tank. 2-The cleaning strength dial was set to normal clean and light clean during my cleanings. I was then referred to a local repair company.
Do you have any suggestions for me to try to fix this at home before taking it to be serviced?
  • tricia Anne May 11, 2010
    who does one unclog the little red spray tips in the base of the cleaner???????? If now solution or water is running through the hand device and the nozel how do you get viniger or lime away to travel through the hose and valves?
  • 48 Answers
First make sure the solution bottle is seated correctly and the machine solution inlet is free from any debris
try the hose part of the machine,
See if water comes out of the hose ; Set the dial to heavy traffic, then put a pencil mark on the solution bottle level with the solution liquid ,
See if the solution level goes down
see if water is coming out of the spray tips under the machine
The spray tips could be blocked .
Posted on Nov 25, 2007
  • 1952 Nov 25, 2007
    If you have been using to much scotch guard the smart mix unit itself could be blocked
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My formula tank is not emptying on my 8910 proheat eurka cleaner
Make sure it is on heavy traffic on the selector set. You may find it is on Clear water rinse. FYI you will find your machine will clean better and your carpet will be cleaner if you use a weed sprayer and mix your soapin it. Just spray it down fairly heavy and let it set for 10 minutes. Then just use straight water in both tanks and you will be amazed. It is like a lasagna dish if it soaks for a while it comes cleaner easier.
May 13, 2014 | Bissell 8910 ProHeat Clear View Upright...
How to unclog a bissell proheat turbo carpet cleaner
proheat 9300
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Nov 24, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
Not sure where water goes ? in bladder and with solution on back
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
qwewr
Apr 25, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
BISSELL PROHEAT 2 X Cleaner
The nozzles on the bottom sound like they are blocked .
Dec 30, 2017 | Bissell Vacuums
Bissell 9400 ProHeat Upright Wet/Dry Vacuum Logo
259 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
