Question about Dryers
I have speed queen commercial model stb 7500 and sr.otck9501032162.gas flame shuts off after 15 to 20 seconds.I replaced airflow swich duct cleaned.replaced therostat.but no luck.When turned on I can see flame in few seconds,dryer runs on but flam shuts off in 15 seconds. can you help me to find what i need to do next or replace.
  • 1 more comment
  • aruncamera Jul 31, 2009
    burners are clean. they are not clogged. If I turn on again it will show flame for few seconds and flames shuts off after 10 seconds
    dryer run on but flames shuts off in 10 sec.
  • aruncamera Aug 01, 2009
    thanks for advice I will try and let you know.arun
  • 15,935 Answers
Sounds like your thermocouple/Flame sensor failure.
Many times it can be cleaned with fine grit sandpaper - but its best just to replace it once you have the machine torn down.
The thermocouple converts the flame(heat) into very small voltage that lets the gas regulator know to stay open.
It is not sensing the proper voltage after heating up - so is shutting down so your room doesnt fill with gas and explode :D
Please accept this answer to remove it from the work queue - and re-post additional questions.
Posted on Jul 31, 2009
  • blueextc3221
    blueextc3221 Jul 31, 2009
    one other thing - Based upon the problem description which is a common symptom, when one of the solenoid (coil) fails or becomes defective.
    Replace both solenoids, which are located on top of the gas control valve. An easy and inexpensive do it yourself repair. No testing is required to accomplish this type repair.
    The solenoid coils are mounted directly on top of the gas valve. Each has a wire harness assembly with a plastic quick disconnect attached. The coils (solenoids) must be removed and replaced.
    Flame sensor/thermocouple/( of the side of the flame tube ) is common but not nearly as common as the coils themselves.
    You can actually just remove the gas valve (solenoids and all) and have it refurbished at a local appliance repair store. They will replace the coils and check for leaks at the seals.
    Thanks :D
  • 520 Answers
The burner may be clogged with dust. This is common with gas dryers. The regulator may also be the problem. If it is not flowing properly then it will starve the burner for gas. Try cleaning the burner with a vacuum first. If this doesn't work then call out your local gas company to check the pressure at the regulator. These burners require a large flow to function correctly. Hope this helps. Please re-post with updates or questions. If you feel that this solution has helped then please accept and rate. Thanks cj2176.
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Y wonnt the flame shut off
Model #? Problem is not clear. May be blocked airflow from filter trap all the way thru the 4" duct outside the back of the dryer OR may be faulty gas valve that doesn't completely close when "OFF."
Oct 16, 2014 | Dryers
Speedqueen flame stays on for only 30 seconds then goes out, puffs back towards gas valve
when was the last time you cleaned out the dryer and vent line,if the air can't move to the outside vent the gas will shut down,remove the vent line from the back of dryer to see if it runs longer,also clean out the duct where the lint filter slides into,it sounds like you have lint blockage either in the dryer or in the vent line.
Jan 15, 2014 | Speed Queen AGS17AWF Gas Dryer
Speed Queen dryer burner lights but does not dry clothes
This is a symptom of a severely clogged up vent or dryer passages.
Remove the vent duct hose from the back of the dryer and see if the problem persists. If it workes normally clean out the ducting and the through the wall flapper vent.
If the problem persists then remove the lint filter and inspect the air passages inside the dryer. Also check the exit hole where the vent duct connects for lint buildup. Use a crevice tool / vacuum to clear all dryer passages. If necessary use a folded coat metal hanger to assist in removing lint build up.
Wash the lint filter with whie wine vinegar and then soap and water to remove the dryer sheet particulate matter that builds up on the lint filter.
If the burner lights but goes out after 30 seconds then the flame sensor on the top of the burner assy ducting is bad.
Thanks for using FixYa.
Kelly
May 12, 2010 | Speed Queen AGS28AWF Gas Dryer
Speed Queen gas dryer won't heat
probably not most likely bad coils on gas valve the 2 black dohickys with wires
Jul 23, 2008 | Dryers
Dryers Logo
Top Dryers Experts
