Do i have to add water to the uniot to make it
Do i have to add water to the unit to make it cool?
    Sergeant:
    Champion:
  • 246 Answers
No. Water is not what makes an AC cold. It is a refrigerant gas called Freon. Water is only a by-product of an AC system caused by condensation. If your AC is not blowing cold air the system might be either low on Freon or completely empty due to a leak. It should be checked out by a certified AC specialist.
Posted on Jul 31, 2009
Why is my 8000 btu portable air conditioner leaking water all over the floor
IF this is a regular unit and not one that you add water too (like a swap cooler) it is normal for water to be produced. When those units cool the air, the water in the air condenses in the coils and drips down to a pan in the bottom. There should be a light that comes on and tells you to empty it and there should be a plug for emptying the unit. If it is leaking then the there could be issues with the tray and where the water is going.
Jun 09, 2017 | Heating & Cooling
Having trouble with it cooling down the room, dont know where to add water
Most air conditioners do not require water. Which brand and model A/C do you have?
May 04, 2015 | Heating & Cooling
The air coming out of my Haier CPRB09XC7 Portable Air Conditioner has gotten warmer and dryer. I'm sure that i need to add water but i do not know how as the manual was lost a while ago. Do I just need to...
Actually, sportsfan, you don't need to add any water. In fact, there is no way to do it. Your unit works much the same way a dehumidifier does with auto evaporation function. In other words, it collects the humidity out of the room air a evaporates it, so there is no water removal on your part involved. While this water is being evaporated, it's also being cooled, so that cools your room. The hot air of the unit running is exhausted out through the window vent kit.
To replace your Owners Manual call Haier Customer Support 877-337-3639
Hope this helped answer your question. Please let me know. Thanks.
May 04, 2011 | Haier CPRB09XC7 Portable Air Conditioner
Just bought the washer and dryer. Dryer works washer does not how do i hook up washer
Hi .. There should be a seo\parate power cord for each unit. If there is not a separate cord , then look for a cord the interconnects the two uniots .
May 03, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Will not take a charge
if the unit will not charge then the internal battery is defective and it will need to be replaced, the batteries in these uniots last about 2 years on average.
Feb 27, 2010 | Tomtom ONE XL GPS
Bosch dishwasher not letting water in to the unit. I have checked the water inlet and there is water coming through. However there is a electrical smell to the uniot and seems not to be going through its...
you need to replace the water inlet solenoid valves as a unit,you can normally do this from outside the unit,some you may need to remove rear cover to replace it
Jan 17, 2010 | Dishwashers
Top hose hot and bottom hose cool...replaced radiator,condenser auxillary fan unit/resistor, replaced harness (spliced) from aux fan unit to temp sensor in the radiator...fan wont work and I dont think...
sounds like your water pump is air bound ( there is a air bubble in your cooling system,or your water pump isn't turning.Bleed the cooling system by jacking car upso the antifreeze fill area is the highest point and run the engineat 1500 rpms add water if it goes down that tell you that the water pump is pulling.Also see if you have a air bleed on the cooling system.Keep the rpms up until you can't add anymore water then put cap back on before returning the engine to normal idle speed.
Aug 09, 2009 | 1994 Volkswagen Jetta
We just got this air conditioner and it did not have a manual, do we need to add any water to this unit?
You do not need to add water to the air conditioner. Water will form and drain outside when it cools the space down, as it also pulls moisture from the air.
Aug 05, 2009 | Goldstar R5208 Air Conditioner
Model rs2533sw panel not reseting after being unplugged
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
Dec 24, 2008 | Samsung RM255LASH Side by Side...
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
