Question about TriPro Power Computers & Internet
Model#POF-600S battery dead?
Model#PO-600S (Serial# 0312001047) is "chirpping" while connected and turned on. Can the battery be replaced by consumer? Where do you get them?
    Habit-Forming:
  • 120 Answers
These are replaceable, there is a slot on the bottom where the batteries come out. Sometimes the covers are screwed in. You have to get the model of the battery. Also get the size with a ruler, just in case. There are places on E-bay that sells them. What will hit you is the shipping. These are lead-acid, lead is heavy and expensive to ship. Contact one of the sellers and get a price with shipping. Then compare this with a new model from a local store. I have swapped out batteries a few times and the USP is still running.
Posted on Aug 02, 2009
The fridge makes a loud chirping sound every few minutes (like a smoke alarm indicating its battery is dying).
I think a door open sensor is not working properly???
If the door close sensor has failed, a new one is in order. if it's physically fallen from its installed position it may be repaired easily?
Manual says chirping can be compressor restarting... Or Ice maker pump running without water supply. Off for icemaker is in rear left lower backside of the unit.
Cheers,
Chance
San Diego, CA
May 13, 2016 | General Electric Refrigerators
Chirps come from ceiling not unit
Only the smoke detector will chirp. When they begin chirping it means the battery is very low and needs to be replaced. Replace it and you will find the chirping will stop as it will when the battery is totally dead.
Jan 08, 2016 | Home
Battery connection on new alarm Light Your Way Smoke and Fire alarm
If the battery will not make a connection, it may not be installed properly. The connector requires firm pressure.
My First Alert instructions say to "press and hold the test button on the cover for 5-20 seconds, or until the alarm sounds".
Nov 07, 2013 | First Alert Sa304Cn3 Smoke Alarm Escape...
NOTIFIER SMOKE ALARM PROBLEM WITH CHIRPING ALL NIGHT
Could be time for a battery replacement unless these units are hardwired
Dec 14, 2012 | Honeywell Notifier Sib-2048 Fire Alarm...
Where can I purchase a replacement 5 point harness for the above model ?
You will need to go directly to the manufacure.
You must have your model number and manufacturing date of the product to order parts, accessories, or instructions.
To order, e-mail the Consumer Relations Department at consumer@djgusa.com, fax at 1-800-207-8182, or write to the following address:
Dorel Juvenile Group Consumer Relations Department
P.O. Box 2609
Columbus, IN 47202-2609.
You may also contact the Consumer Relations Department at 1-800-544-1108 where you can speak to a Consumer Relations Representative.
Hours of operation are Monday - Thursday 7:00 AM to 6:00 PM EST and 7:00 AM to 4:30 PM EST on Friday.
Mar 09, 2011 | Cosco Summit 22260 - Houndstooth
Replaced 9 v batteries, units still chirping
This is the troubleshooting information from the kddie site. The problem is usually related to an older battery or improperly installed battery. You might also have to do a reset as described below. If battery and cleaning don't work, it might be time for a replacement - short money to keep you and your home safe.
  1. The battery may be loose, or improperly installed.
    Verify that a battery of the recommended type is securely installed. Make sure to use a battery with a use-by date no later than four to five years in the future. Check that the battery is snapped in completely so it cannot be shaken loose. It’s possible that battery connections may not be making good contact with the battery. Disconnecting and re-connecting the battery once or twice will likely fix this condition. On units with a front-load battery, be sure that the battery compartment door is closed completely as well. Loose white neutral wire can cause an echoing chirp. (From one unit to the next)
  2. The smoke alarm sensing chamber may be dirty.
    Dust and insects can collect in the sensing chamber of the alarm. An accumulation of dust in the sensing chamber can cause the unit to chirp. It is good practice to clean the smoke alarm when you change the battery. Static electricity from the ac quick connector attracts dust and can cause false alarms.
    Cleaning smoke alarms:
    To clean your alarm, remove it from the mounting bracket as outlined here. You can clean the interior of your alarm (sensing chamber) by using compressed air or a vacuum cleaner hose and blowing or vacuuming through the openings around the perimeter of the alarm. The outside of the alarm can be wiped with a damp cloth. After cleaning, reinstall your alarm, verify the green LED is on and test your alarm by using the Test Button. If cleaning does not restore the alarm to normal operation, the alarm should be replaced.
  3. Check environmental conditions:
    • Humidity, steam and condensation can cause false alarms. Causes of condensation are:
      • Extreme temperatures changes.
      • High ambient humidity.
      • Unit being installed in an uninsulated electrical box mounted on a ceiling beneath an attic. If this condition exists you’ll want to move the alarm. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check to see if there is a cooling/heating register, a ceiling fan or an open window within 3 feet of the alarm. If there is, move the alarm away from the source of the increased airflow. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check the temperature of the room. Smoke alarms operate at 40 degrees to 95 degrees Fahrenheit. Carbon monoxide alarms operate at 40 degrees to 100 degrees Fahrenheit.
  4. Reset the alarm.
    Some current model smoke alarms have a processor that retains certain error conditions, such as a weak battery. The error condition should reset when the battery is replaced but sometimes it does not and must be manually reset to clear the error.
    To reset an AC unit with a battery backup:
    Turn off the power to the smoke alarm at the circuit breaker.Remove the smoke alarm from the mounting bracket and disconnect the power. Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reconnect the power and reinstall the battery. The unit will chirp once when the power is restored and should not chirp afterwards.
    To reset a DC only unit:
    Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reinstall the battery. The unit will chirp when the battery is first connected but should not chirp afterwards.
  5. An electrical condition may be causing the power to the unit to be interrupted.
    If the AC power to the unit is interrupted, the unit will chirp when the power is restored. This could be caused by power surges.
    If the chirping seems to occur at about the same time in the evening or morning, it could be due to a surge created when the power company switches electrical grids to meet demand. Check to see if the chirp (or chirping) occurs when something else in the house is turned on such as an exhaust or attic fan, a heater, etc. If the smoke alarm is connected to a circuit with such a device, the alarm may chirp when the other device is switched on. If this is the case and the device is plugged into a wall outlet, move it to another outlet on a different circuit. If it is a hardwired device, have an electrician investigate it. These conditions can be minimized by installing your alarms on a dedicated circuit in compliance with NFPA requirements.
  6. Replace the alarm.
    If none of these conditions exist and the suggestions don't alleviate the symptom, the alarm should be replaced. Age may be a factor. Smoke and heat alarms should be replaced every 10 years, and carbon monoxide and combination alarms should be replaced every 7 years. Most of our alarms have a 5 year warranty from date of purchase (check your user manual for details). A date code is stamped on the label attached to the back of the unit.
Feb 02, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
My First Alert Carbon Monoxide Alarm has failed
If the carbon monoxide detector chirps, the battery may be dead. New batteries can be defective. Check if the light is yellow when the alarm is chirping, it means the battery is low, replace with a new battery.
Warranty service information:
UNITED STATES
BRK Brands, Inc.
3901 Liberty Street Road
Aurora, Illinois 60504
For consumer inquiries call: 800-323-9005
CANADA
Jarden Branded Consumables Canada
88B East ****** Creek, Unit 6
Richmond Hill, Ontario, Canada
L4B 4W2
Tel: 905-482-3720
Fax 905-731-8267
For consumer inquires call: 800-323-9005
If you are looking for new Carbon Monoxide Detectors, visit my website.
Oct 01, 2009 | First Alert Safety & Security Carbon...
Looking for a cosco 2 in 1 crib part.
To get replacement parts contact Cosco's Consumer Relations Department. When you call them better having your model number and purchase date available. To order, send an e-mail to the Consumer Relations Department at consumer@djgusa.com, fax us at 1-800-207-8182, or write to the address: Dorel Juvenile Group
P.O. Box 2609
You can also contact the Consumer Relations Department at 1-800-544-1108 to speak to a Consumer Relations Representative. Hours of operation are Monday - Thursday 7:00 AM to 6:00 PM EST and 7:00 AM to 4:30 PM EST on Friday.
This can be the right choice if you do not have model number for your crib.
Sep 21, 2009 | Cosco 2 in 1 10-185-WHO Crib
Computers & Internet Logo
127 people viewed this question
Top TriPro Power Computers & Internet Experts
M_Butkus
Brett Duxbury
Brett Duxbury
Are you a TriPro Power Computer and Internet Expert? Answer questions, earn points and help others
