SOURCE: bag light stays on, powers on then shuts off immediately. What is the problem?
first check to make sure there is a bag in the machine, if so make sure that its in securely, there is a pin switch in the bag door that wont allow the machine to turn on if there is no bag in it. If that's okay, then find the knob on the top of the machine ( in the middle of the canister ) and make sure its turned to the maximum, that is a sensitivity knob that can keep the machine from working ( in case it was clogged, but if its too sensitive it could think the machine is clogged when it really isn't ).
SOURCE: Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
SOURCE: My electrolux vac shut off for a full bag. After
If the suggestion that renevacdoc did not work, it is most likely that your valve assembly(full bag control) has gone bad and needs to be replaced. You will have to take your vac to the Aerus/Electrolux dealer/service store for repair.
Joe
SOURCE: vac keeps shutting itself off!?
This problem is caused by the static electricity which causes the hose controls to jump back down to the off setting. I have seen this issue on several Silver Moon and Blue Moon models before.
The only way to fix this problem is to purchase a brand new, redesigned hose. The new hose can be purchased here; Miele Electric Hose Miele Part # SES 125
In fact, I'm so sure that this new hose will fix the problem to your Miele, that if you do purchase the hose from GoVacuum, we'll give you a 60 day satisfaction money back guarantee. If this hose doesn't fix your problem, you may return it to GoVacuum within 60 days for a full 100% refund, no restocking fees or shipping charges will be deducted. We'll even include a free return label you can use to return the hose to us at our expense!
If you have any questions, please feel free to send me an email, or request a clarification. I hope this helped you. If you found this solution helpful, please remember to rate this solution as helpful by clicking on the four THUMBS UP icons in the top right hand corner of this solution.
Thanks so much,
Chris Jones
GoVacuum.com
SOURCE: The bag light stays on,
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA (control valve assembly) are clogged and simply need cleaned. This should be performed at an authorized Aerus Electrolux store only.
Second, check the afterfilter. This should be changed after every six bags. It's located beneath the tool caddy on the back of the machine. Press in the tab and lift tool caddy. If the filter is dirty, remove and replace. If you're out, try running the vacuum with no afterfilter.
I mentioned the CVA earlier, and a broken or worn out CVA will cause the vacuum to not start/run. This is an internal part and needs to be replaced by an authorized Aerus Electrolux service tech. Use the same check as above; detach hose, switch vacuum on. If it doesn't come on, it's most likely a bad CVA.
