Question about Minn Kota Boating
My 48v 2hp minn kota e drive stopped working. batteries re charged ,it went in reverse and when we went in forward it went dead
tbirdfan1
  • 3051 Answers
SOURCE: Where can I get installation manuel for Minn Kota bow mount maxx?
Hi there
if you go to the web site of the manufacture they havre a printable version of the manual there is even a phone number to call for help please try this ok and let me know how this works for you
best regards mike
Posted on Mar 06, 2009
SOURCE: I lost istallation manual for minn kota power
Contact the people at this Email address. Minn Kota <Motors@johnsonoutdoors.com> The address is between the brackets. They emailed me a manual for a different trolling motor. They are nice folks. It will take up to a week for you to get a reply.
Posted on Jun 05, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Posted on Jul 13, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
What is amp. draw of minn kota 40pd? thanks
Digital Maximizerâ„¢
Digital Maximizerâ„¢. Up to five times longer run time on a single charge.
Conventional speed coil technology wastes energy by delivering a constant, steady flow of power to the motor regardless of the speed setting resulting in wasted energy.
Pioneered in 1985, Minn Kotas innovative Maximizerâ„¢ technology delivers the precise amount of power needed at any setting, along with variable speed control. Now, our advanced, digital microprocessing optimizes draw to extend battery life and reduce damaging heat. Get up to five times longer run time on a single charge.
Would think you would have to ask direct, but standard practice is to run your Minn Kota from a separate battery anyway, so the draw is pretty irrelevant to main engine starting.
your manual is here and states it has a battery level meter.
http://www.minnkotamotors.com/Support/Owner-Manuals/PowerDrive-V2/
Minn Kota Motors
Jan 06, 2016 | Minn Kota Boating
Minn kota trolling motor has forward but no reverse
Don't know what Minn Kota you are talking abut but my 55 pound Thrust one does NOT have a Reverse.... When I want reverse I swing the Prop all the way around so it is pulling the boat backwards..... I just checked it to refresh my memory......
May 08, 2014 | Minn Kota Boating
Minn Kota mk25 light will not move from yellow to green. I have moved the connections from one battery to another. I replaced a dead starter battery, and my trolling battery tested out at 100%. what could...
Do you remove the trolling motor wires before charging..? ...If not.. try that......mine started taking a LONG time to charge.. after I remove the trolling motor cables.. it take less time and charges better!!!
Feb 25, 2013 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
My Johnson Escape boat w/ Minn Kota engine stopped running
I've had the same problem. It steams from the control panel. I took and ran a seprate ground wire directly to the motor. This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to replace rotary switch and circuit breaker. These also are trouble-some parts.
Aug 01, 2010 | Minn Kota Boating
Motor works then stops. If I pull the motor up
I have the exact problem with my Minn Kota 70 - did you find an answer? Thanks, MJJ
Jun 23, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota tolling motor
Reverse the polarity on the trolling motor by taking the trolling motor apart and turning ithe motor housingt 180 degrees and bolt it back up. The polarity will be straight then. I did the same thing when I pulled the armature back in.
Nov 24, 2007 | Minn Kota Maxxum 70 Universal Motor/Sonar...
Boating Logo
146 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
