Question about Garden
I was mowing today and as I passed a tree the spark plug wire got yanked off the plug by a branch. I reconnected, but now it won't start. Have pushed down hard to make sure cap is seated on plug, but nothing.
  • tniccum Jul 31, 2009
    Thanks. I concluded that the wire or coil/magneto was damaged and ran it over to the dealer, they agree and will fix it - possibly under warrantee.
    President:
  • 1,776 Answers
I would check out the wire. Sounds like it got yanked hard enough to put some serious pull on it. Start at the end that plugs on the spark plug and work your way to the magneto. Look for any obvious damage. I sure hope not, but I had a similar thing happen once and it costs me a new magneto. Hope this helped and best wishes.
Posted on Jul 31, 2009
  • Bruce Canfield
    Bruce Canfield Jul 31, 2009
    Also check the plug over carefully and make sure that the porcelain isn't cracked and that the plug is not damaged in any way.
Tatarian Maple leaves growing out of trunk, should I remove those branches or buches clear from the ground up as that is how they are growing?
G'day Patti, unless you want to look beyond the tree it would be advisable to leave the lower leaves and branches. The lower branches hide little critters from big critters. Cheers Greg.
Jun 11, 2016 | Garden
While parked a tree branch fell on the truck now it won't start it ran fine before the tree branch fell
A Tree Fell on Your Car: Now What?-Allstate
https://www.allstate.com/tools-and.../car.../tree-fell-on-car.aspx
Allstate... parking lot to avoid door dings," so you can imagine his dismay when a tree ...Gregg did his best to salvage his truck after the storm passed, but the ... If you're the owner of both the fallen tree and the vehicle, your homeowners insurance policy likelywon't ... What steps should you consider when a tree falls on your car?
Will landlord's home insurance pay for tree that fell on my car?
www.insure.com > Ask the Home Insurance Expert
Jun 4, 2014 - If a storm causes a tree at your rental property to fall on your car, don't expect ... Will landlord's home insurance pay for tree that fell on my car during a storm? ... The landlord, thus, won't be found liable by the insurance company and ...damaged if you also knew of the tree's fragile condition and parked by it.
Responsibility for damage caused by falling trees is a ...
www.post-gazette.com/...falling-trees.../2012112...
Pittsburgh Post?GazetteNov 23, 2012 - Pittsburgh Then & Now ... The philosophers wanted to know what happens when a tree falls in a forest. ... and knock branches onto your home, causing serious damage." Coverage ... But if you do the same to your own property, your own auto policy probably won't cover damages to your trees and shrubs.
DOT hits tree, tree branch damages legally parked car ...
Jan 25, 2016 | Cars & Trucks
I mowed three rows. Stopped the mower to move some branches and now it will not start.
check for spark at plug squirt some starting fluid in it see if will start make sure kill switch not engaged sounds like valve isnt seating do a compression test should be 90 to 125 lbs
Jul 12, 2014 | Garden
Where does the throttle linkage spring attach on each end on a Yardworks 173cc 21" (Model# 11A-A2M7515)? I was mowing the lawn and pushing the mower close to a tree and a branch popped off the spring.
there is a little tab behind the air filter but facing forward. it is a funny shape. hook the spring end over this tab and you should be good to go
Jun 29, 2014 | Garden
Craftsman silver won't start
ground the spark plug to the engine block it should spark. sounds like you need to check the valves and push rods
Jul 04, 2017 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Jun 07, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
May 23, 2012 | Husqvarna Garden
Gas golf cart won't start
try a jump start off of a similar battery with the same voltage. If that does not work, there is a chance your ignition wire is not wired into the throttle anymore. try reconnecting it.
Apr 23, 2012 | Sport & Outdoor - Others
1990 honda civic ex won't start
un plug wire and see if it starts if not then check the fuses after that hope this helps you.
Mar 27, 2012 | 1990 Honda Civic
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
