It has stopped spinning. Everything else seems to be working. Can we maybe troubleshoot this problem by ourselves?
  • sronstadt37 Jul 31, 2009
    JagDave
    Thank you for your response.. I'll Let you know if we have any success. Shari
    Scholar:
  • 44 Answers
Yes, maybe you can. Does it wash OK? i.e. the drum rotates but does not spin? If so, likely to be programmer. If no rotation at all on the drum, likely to be the motor or the belt. To find out which, take top of machine off and look to see if you can see the motor pulley - if it spins when you put it on a normal wash cycle, but the drum doesn't, it's the belt and an easy cure. In general terms: Belt=easy cure. Motor=new motor not too expensive, depending on machine quality, quite often worth the price. Programmer=unless you have a top end machine like a Miele, very expensive and you are looking at a new machine. PS some machines have a switch to cut out the motor if it spins too far out of balance - these can get damaged if you had a big load in and the drum really moved a lot. Look to see if you have such a switch and check it is not damaged. It will typically be on or near one of the suspension legs.
Posted on Jul 31, 2009
When i put my machine on to spin the clothes are coming out very wet, I have cleaned out everything, everything seems to be working properly, The pump is fine, Can you tell me what is wrong I use onl
Depends how old your machine is Sounds like your motor maybe wearing out. Does it make any noises. Make sure your not putting in to many clothes weighting it down. Try spinning a very little load see if they come out ok. If not MOTOR.
Jan 21, 2015 | Washing Machines
How do i recharge freon for me Friedrich KM18J30A-3 window unit?
only a certified HVAC technician has the license to carry and use the freon used in home A/C units. it's not like the car units we can do ourselves.
Jul 14, 2012 | Friedrich QuietMaster KM18L30 Wall/Window...
Won't spin at end of cycle. Maytag top load washing machine
RITS REAL COMMON WITH THAT MODEL FOR THE BEARING TO LOCK UP. TURN THE TUB BY HAND A LITTLE THEN TRY SPIN, IF IT THEN RUNS YOU NEED A BEARING/SEAL KIT.GOOD LUCK
Jan 16, 2010 | Maytag SAV5710 Top Load Washer
Machine won't spin... Machine gets water,
only be one thing, the wig-wags are not shifting transmission into spin if everything else seems ok in operation
Aug 23, 2009 | Washing Machines
Washer not spinning
It's either the motor,the condensator that stores electricity which then starts the motor or finally the pcb being faulty here.It might be the door switch even but you can't tell unless it's checked
Aug 03, 2009 | Washing Machines
Maytag washer stops during spin cycle
it seems like aproblem w motor maybe need to acouple of new carbon brush to fit in motor
i think that because it seems to me from your words that the motor only works w no load
thanks
Jul 11, 2009 | Maytag Dependable Care LAT9706
Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Microwave Turntable doesn't spin
Hi
Sounds like the turntable motor has packed up.
Normally this is located underneath the microwave and should be readily available as a spare part.
BE WARNED i would NOT suggest taking the cover of the machine. There is a capacitor in there which stores 5000 volt and if you dont know what you are doing it can kill.
Please leave feedback
Rob
Feb 12, 2009 | Microwave Ovens
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
