Question about Metra Ford F 150 Truck 96 Up
2006 FORD F-150 SUPERCREW 2WD.BRAKE LIGHT ON INSIDE STAYS ON.....HAVE REPLACED ALL BRAKES ALL AROUND
  • 77 Answers
The problem is usually either the fluid sensor or the abs system.
Posted on Jul 31, 2009
My brake tail lights stay on and my right turn signal comes on no flashing hazards stay on only left side blinker works
For your brake lights, your brake switch is faulty. Probably located somewhere around brake pedal. Replace it and check, you can D.I.Y.
Jan 31, 2016 | Hauler Racks 2000 Ford F-150 - Flareside...
My 2006 f150 has new brakes and rotors,fluid full but my dash brake light stays on. Soon as you start it and the whole time you drive. Also the cruise quit too. Once the light went off then the cruise
This sounds like the brake light switch or the control switch on the brake pedal is bad or loose. Check under the dash above the brake pedal there should be one or two switches that tell the brake lights to come on and the cruise control to shut down.
Feb 13, 2015 | 2006 Ford F-150
2006 f150 brake warning light stays on
Same problem, it's the fluid/parking brake light so you can't scan for codes, it shouldn't happen, just had the brakes done. The shop monkeys can't figure it out. Help.
Mar 27, 2012 | 2006 Ford F-150
Brake lights and turn signals quit working fuses are good and i replaced flasher relay this is a ford f 150 supercrew 2003
your problem is fix is easy your problem is the connection where the light bulb plugs into holder. Take bulbs out and clean plug contacts with a fine flat file, then make sure bulbs are pushed back correctly. And you problem should be solved.
Oct 09, 2011 | 2001 Ford F150 Styleside SuperCrew
07 f150 supercrew got it new brakes are sponging ever sence it was new at red light brake peadle bleeds down
Your description sounds like you either have a leak or a damaged master cylinder. If you determine the m/c, BENCH bleed it before installing. Auto parts stores sell an inexpensive kit to assist in m/c bleeding.
My bet is failed master cylinder.
Jun 22, 2011 | 2006 Ford F-150
Not a regular cab but Lariat F-150 Supercrew 2003 , the inside and the cargo lights stay on when the truck is shut down ,and now I notice the auto locking doors are not working when you touch the brake...
Is the door ajar light in the cluster illuminated ?
Could be the door ajar switch ( part of the door latch ) is gummed up, and needs to be WD-40 sprayed into it, and close open the doors a few times, and repeat.
The autolock uses the same input, to know to lock the doors when you press the brake pedal while moving.
Mar 26, 2010 | 2003 Ford F150 Regular Cab
How do you adjust the emergency brakes on a 2001 f150 supercrew?
If you have disc brakes, there is no adjustment and the emergency/parking brake as no effect on pedal travel. The emergency/parking brake uses regular drum type shoes working in a small drum inside the rotor and is independant of the service brakes.
Dec 22, 2009 | 2005 Ford F-150
Ford f-150 brake light and blinker problems (from towing)
Check the fuse box located in the cab down by the drivers left knee. check all the fuses there, also consult your manual and check the fuse for the brake/tail lights. This sounds like a fuse problem more than anything. Thanks for using fixya! Good luck!
Sincerely,
JC
Dec 29, 2008 | 2006 Ford F-150
Problems with pressing brakes to stop
U either have a leaking power brake booster or a loss of vacuum to the booster.
Dec 24, 2008 | 2006 Ford F-150
Metra Ford F 150 Truck 96 Up Logo
104 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Jason
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
