Question about Performance Teknique ICBM-782 Car Audio Amplifier
I want to bridge my icbm 781 amp i dont know how to bridge them
    Problem Solver:
  • 7 Answers
It is already "bridged" it's a monoblock amp, 1 channel, if you're trying to get more power, lower your ohm rating..here's a guide to wiring subs for different ohms: http://www.crutchfield.com/S-vXEiF19AwhE/learn/learningcenter/car/subwoofers_wiring.html
Posted on Aug 01, 2009
Need to see the diagram to bridge amp
Bridging an amp is as simple as using both channels for one hookup. By this i mean use the negative slot from one channel and the positive from the other. Not all amps are bridgeable however, so if yours is there will be a line showing which channel to use the positive on and which one to use the negative on.
Aug 10, 2012 | Performance Teknique ICBM-Digital Car...
How would u bridge 2 fosgate punch hx2 to this technique ICBM 9550 2600watts
  • Hi, I can help.
  • As I look at the manufacturer specs and recommendations this amp is not brigable. I figure I would tell you so you did not ruin it.
  • When you bridge you turn 2 channels into 1 channel. This is already a 1 channel amp. Bridging would ruin that amp quick.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 27, 2011 | Performance Teknique ICBM-9550 Car Audio...
The diagnostic LED indicator comes on and i dont know why
first check the ground as it is the most important par to the wiring and operation of an amp. itshould be t the frame of the careand touching clean bare metal no paint! if that doesnt work it may be going into termal protection meaning ts getting too hot. you should always be able to continously keep yourhand on the amp, if its too hot try backing the gains down a little. next make sure the spakers are ired to a safe impedance for the amp. if its wired too low it might could put the amp into protect mode or blow it! most amps are only 2 ohm stable nd 4 ohm stable when you bridge them...hope this helps!
Sep 15, 2010 | Performance Teknique ICBM-775 Car Audio...
Dont know how to connect daul voice coil on a icbm-5612 performance teknique.
If you want a 2 ohm total load..wire it from the amp positive(red) to the first coil positive(red) and then to second positive(red). Amp negative(black) to first coil negative(black) and then to second negative(black). This will give you a 2 ohm total load on the amp.
Apr 21, 2010 | Performance Teknique ICBM-6112 12" 4 Ohm...
No knowledge of how to hook two subs which are the 12 alumni audiobahn sub to a performance technique 781 mono block amp operation ohms for the speakers say 3 or 12 ohms during operation can i bridge or do...
yor subs have dual 6 ohm voice coils from the sound of it-your amp is rated at 650 watts rms at a 1ohm load. The best you can do with the equipment you have is to wire ALL the coils of your subs in parallel and that will give you a 1.5 ohm load for the amp.It should knock the hell outta them with 300 watts on each sub - good luck
Jan 14, 2010 | Performance Teknique ICBM-782 Car Audio...
I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
Hello perezmagdiel,
That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
Hope this helps.
Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Dec 21, 2008 | Performance Teknique ICBM-Digital Car...
Performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
Not enough power delivered
This sounds like a gain setting problem on your amp. The best way to adjust is to set your volume on the head unit to about 75% volume and then adjust the gain up until it sounds distorted a little. Back it off jst enough for the distortion to go away and you are set. Only other thing to try is use a multimeter set on Ohms to test the resistance of your speaker configuration. Looks like 2000 is th peak power (not RMS) and is only possible at high current configurations. You are probably running at 4 Ohms, but this amp only puts out rated power at 1 ohm stereo or 2 ohm bridged. Many people say Performance Technique are overrated, so maybe not even what it is rated at - 350 x 2 @ 2 ohms bridged (probably only about 175 x 2 at 4 ohms bridged)
Feb 06, 2008 | Performance Teknique ICBM-9540 Car Audio...
Bridge a not bridgeable amp
It will probably blow a fuse or blow up completely.
When the output stages ar not lifted from ground
as is the case in a bridgeable amp bridging cannot
be done.
Jan 12, 2008 | Performance Teknique ICBM-782 Car Audio...
Performance Teknique ICBM-782 Car Audio Amplifier Logo
217 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Joe Alexander
Joe Alexander
woodzowl307
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
