Question about Sharp AR-5316 Advanced Digital Imager Copier
After few hundreds of copies, the main charge is dirty, so get poor quality. Sponge roller in the toner hopper is a new one.
    President:
  • Sharp Master
  • 990 Answers
Hello sir; You may go to simulation 26 sub code 18 turn off the toner save mode, will be help you; the procedure as follow;
press "#" "interrupt" "c" "interrupt" enter 26 press start,enter 18 press start, enter 0 press start. press "clear" to end the sim.
Posted on Jul 31, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Print copies have a grey cast. i replaced the toner cartridge holder but am still getting a grey cast. i have been using off brand toner replacement through amazon. i hope this can be fixed.
it can be that the drum cleaning blade is poor quality or charge roller fault. To avoid the low quality repair of toner crg's and possiblle troubles related to repaird crg burst, use only original supplies or buy from verifed toner remanufacturers!
Sep 15, 2011 | Brother DCP 7010 Multifunction Laser...
Canon ir5000 copies have horizonal bands of light copy quality. How do I get even, good quality down the entire page?
The machine probably needs a service paying attention to the development and the cleaning areas. Also, clean or replace the corona wires and check that there is no flat spots on the fuser roller.
Jun 18, 2010 | Canon Office Equipment & Supplies
Ricoh aficio 1515 printing faded images on one side. Just replaced the drum / toner / hot roller. Same issue when printing and copying What else could cause the problem?
Could be one of a few things:
Most likely is the transfer roller. If it's dirty or old and not applying enough charge, it may not be pulling all the toner away from the drum. Replacing the transfer roller is easy if you can get a new one.
Are you sure you have the correct toner? The wrong toner can definitely cause copy quality problems.
If the springs that hold the press roller against the hot roller are not properly in place (or if they have started to lose tension) the toner won't be fully fused onto the paper.
I'd start with the transfer roller (black roller that sits opposite the drum on the right side door) first -- it's the most likely culprit.
Jun 17, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
I have a savin 2522 and it has a few lines running down my copies
few fine lines is due dirty optics mirrors and lamp, and it may also came from dirty charge rollers due to dirty/worn out charge roller cleaner, worn out cleaning blade and seal blade. to check this, clean/wipe off toner or dirt from charge roller with cloth wet from alcohol or water. then run some test copy.
Mar 03, 2010 | Savin Office Equipment & Supplies
Minolta c0072 code, hopper or toner?
C0072: Sub Hopper Toner Replenishing Motor M9’s
Failure to Turn
Sep 03, 2009 | Minolta EP4000/5000 CS/PRO Copier
SHARP AR-287 F2-00 error code
Although this appears to be an ATC (automatic toner control) problem and it may list as such in service manual which gives brief description of error code it is often something else.
There is a sponge roller at bottom of toner that wears down considerably and when the hopper is very low or out of toner the otner light will come on(triangle of dots). The customer puts the new toner in and the sudden surge of a large amount of toner cascading into the hopper causes an excessive amount of toner to go past the sponge roller and directly into the developer unit which is directly under toner hopper.
The ATC sensor is on the bottom of developing unit and "reads" the density of the developer /toner ratio and with a very overtoned situation as the one created above you would get an F2-00 code.
What is normally done is to either dump toner out of hopper and replace sponge roller and seals or replace toner hoppers as a whole which is quicker and costs almost rh same as cahnging the sponge roller and seals is more labor intensive.
Also the developer is now contaminated with an excessive amount of toner and the recommende solutin is to replace the developer and calibrate theu service program.
This is hardley recommended by a service man unfamiliar with this mode let alone the customer. I ahve been in the Bay Ridge area for years and as a matter of fact bought an investment property thru Petses Realty. Frank
May 26, 2009 | Sharp AR-235 Copier
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
Light (faded) print
What's the copy count on the machine?  It could be resolved by adding developer to the unit.
Nov 02, 2008 | Ricoh Aficio 450 Copier
Toner low???
How is the copy quality? Are copies light? If so then the toner hopper is not adding toner to the developer assembly in which case you must call a tech. If the copies are fine then the toner sensor is dirty or faulty and must be replaced.
Jul 11, 2008 | Canon 3045 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
56 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
