Ricoh mpc3500 toner bottle is full. Repair man can't come for a week. Cant even find where the tonor bottle is. Any ideas on how to fix or empty this so we can get running again temporarily?
  • 143 Answers
Open the front door, and then unlatch the lever, then lower the inside door and it should be on the left side behind the inner cover.
Posted on Aug 01, 2009
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
Fix an error message on the Ricoh Aficio 1224c that says 'used toner bottle full'? We have emptied the used toner bottle but the error message persists. What is the best way to fix this?
Check the waste bottle to see if there is a chip mounted on it somewhere. If not see if there is an optical sensor or clear window. If there is a chip it will need to be replaced or a new unit used. If there is a window or optical sensor you should be able to remove it, clean it out, and replace it. These are often the last part to fill with toner and create a light path block.
Feb 06, 2015 | Ricoh Office Equipment & Supplies
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio 2105 waste toner full indicates even if it was already empty, cleaned the bottle sensors still indicates full, how am i going to reset it?
Make sure the 2 waste toner are empty.
You have 2 bottles of waste.
1- Next the papaer trays
2- Next the development Unit
May 25, 2011 | Ricoh Aficio 2015 Copier
I have a Ricoh Aficio MP W2400 plotter. new message is waste toner bottle is full. i know that a service tech is supposed to replace it but due to the weather i cant get one over here. can i empty it for a...
This is for a W2400/3600 which should I assume is the same spec for other Ricoh wide format machines. When you are facing the printer from the front, it's on the right side panel. The waste toner bottle should be about 28" from the ground. Remove all right side panels. There is a sensor (held by phillips screw) that you will need to temporarily remove and reinstall back on to the waste toner bottle once it's emptied. Replace all right side panels. You are good to go. No need to call service tech to waste time. Should be a 30 minute change.
Feb 04, 2011 | Office Equipment & Supplies
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
How do i empty the used toner?
WAIT!!! Don't let Ricoh Steal your money...
You're going to get a little bit dirt with the trick, but there is no need to buy a empty waste toner bottel
Empty the waste toner bottle inside a plastic bag, the dust is kind of azard!!!, when the bottle is empty, clean it from the outside.
Place the bottle in the printer, (This is just for reference only), in the right side of the bottle you're going to see a plastic tag all dirty (You see it?) OK!!, remove the bottle from the printer, and then very carfully remove that plastic tag from the bottle taking care of not ripping it off, now clean the plastic tag, and put it in place again, and now your printer is ready to work!!!!!
Where's the trick?, The printer has a Photo sensor that is "looking" trugh this plastic tag, when the plastic tag is full of toner, the sensor can't get the signal, and then it says that the waste bottle is full..!!!
TONY!!
Feb 05, 2009 | Ricoh Aficio CL3500N Laser Printer
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 17, 2007 | Ricoh CL3000E Laser Printer
186 people viewed this question
k24674
jasbo
jasbo
