Check your voltages when you power it on compared to when it shuts down...see what rail is dropping off for starters, then I can give you more of an idea where the issues are at..I have a feeling you have inverter issues because this was a common failure on this set check and see what voltages drop off after the startup screen
SOURCE: Message on TV screen
Well i fix my problem with an universal remote control of GE here is the link from walmart that is from where u can get it just $6 when u got the control program it with the code 0254 and when everything is working press SHIFT and release and then press Volume+ and the channel set will disappear... Hope this can help
http://www.mountsandmore.com/GE-24912-GNE1003.html
SOURCE: orion 42inch plasma screen tv problem
most likely a bad Plasma Display Panel. Costs more than a new TV
SOURCE: direct tv codes wont work for my emerson tv
code for emerson plasma hdtv is 10812. for direct tv remote.
SOURCE: my emerson tv won't turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
