Question about Saniflo Sanibest macerator with multiple connections
Can i discharge saniflo into bath waste
My plumber says it is ok to discharge the waste from a saniflo into the gravity bath waste in the next door bathroom which then runs by gravity into the soil stack.
Is this ok
Thanks
  • 520 Answers
These usually have a larger drain line than a shower or bath. If you are draining into a smaller drain then there will be a considerable amount of backing up. This is not a good idea. hope this helps. Good luck.
Posted on Jul 31, 2009
Why does it leak from the top outlet?
  1. SANIFLO upflush toilet - YouTube
    ? 6:14
    www.youtube.com/watch?v=-F1v6GIbWF8
    Aug 10, 2011 - Uploaded by Regis Saragosti
    Saniflo is the leader and inventor of the macerating toilet. ...Liberty Pumps Ascent II 1.28 GPF Macerating Toilet System - Install a Bathroom ...
Jul 10, 2015 | Saniflo Plumbing
The bath water won't pump out. Seems like there's too much water left in the Saniplus itself to allow the bath inlet valve to open. Can this be adjusted? The toilet and wash basin are working OK.
This is a bit of a puzzle, if theres water in the Suniplus then the float valve will operate and the water will pumped out as it does for the toilet and wash basin.
I can only think that the bath discharge none return valve is stuck and needs removing and cleaning.
Hope that solves the problem.
Alllan
Mar 26, 2015 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanipro continuously runs,however, not pumping waste away and waste water has filled toilet bowl. Any suggestions
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
Dec 23, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
The toilet waste is coming up into the bath!
have saniplus and the discharge elbow keeps blowing off and spraying a mess. What is causing this to possibly build pressure and burst? I have cleaned out pump and return valve flap is working freely. Please help
Aug 16, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Dirty dishwater comes from the kitchen sink into the bath. What can I do? I have a saniflo.
Try snaking it to check for blockage.I don't know your specific plumbing layout...it depends on the angles,grades,etc. In this case I would try snaking and if that does not help then you might need to call a plumber.
Oct 05, 2009 | Home
Our Saniplus pump runs for no apparent reason. Do I need a plumber, an electrician or a new unit?
if the pump operates then the pump is ok. if the pump switches on for "no reason", this indicates that the saniflo unit is filling slowly with water. as you have a saniplus, then you probably have a handbasin and bath / shower connected to it. If the taps / valves drip, or the wc cistern "leaks" into the bowl then these could be the sources.
Sep 14, 2009 | Saniflo & Saniplus& Macerator Pump
Waste trap under bath leaks
put the putty under the flange where it makes contact with the inside of the bath, push the flange to the bath & tighten nut underneath. Trim off excess. Have an overflow pipe [not intergral] make sure the top & bottom of the collar have rubber seals
If the whole lot is plastic there may well be a leak down & along the thread of the waste.[it comes from the o/flow pipe collar] Silicone the thread and tighten nut. make sure it's dry first - silicone & water do not make a happy couple
Jan 26, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Bath waste is being discharged through wc bowl. anyone help please?
obviously you have a blockage in your line
try to use a plunger to break up the blockage by plunging through the toilet
go under the house or outside and find a cleanout and see if sewage is backed up there when you open the cleanut the sewage will come rushing out
will have to rent a snake or call a plumber
Jan 05, 2009 | Home
Saniflo Sanibest macerator with multiple connections Logo
197 people viewed this question
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
