Question about HP OfficeJet G55 All-In-One InkJet Printer
No copy/no scan
Whenever I initiate a copy or scan, the scanner mechanism just oscillates back and forth about 1" until I hit cancel. No scan occurs, don't get "Scanner Error" or any other indication. Tried taking it apart, cleaning the disk on the motor, lubing the rail, checking for loose cables, cleaning the scan tube with a Q-tip and alcohol, checking the glass for a loose decal - even removed the scanner belt and moved the mechanism back and forth to make sure it wasn't stuck - all with no effect. I don't think it's a driver problem because it doesn't work when pushing the Copy button either. The Print functions are unaffected.
Any other suggestions besides scrapping it?
  • 1 more comment
  • yamee Jul 31, 2009
    Did that ... no change. It appears that it initializes and finds its home point just fine. It's the little motor (to which the clear 'colimator' wheel is attached) that seems to only make a few revolutions before reversing itself ... over and over. I suspect the scanner mechanism is not the problem; either the motor is not reading the wheel right, or the message isn't getting through, or ??? I haven't opened the body of the box to check the boards inside ... not sre what I'd do ifI did!
  • yamee Aug 01, 2009
    Komguy, thanks so much for your help. It's been a frustrating problem, to say the least. How do I do a "full reset"? I might as well give it a try ... !
  • yamee Aug 02, 2009
    President:
  • 2,306 Answers
Down inside that scan assembly are mirrors and a lens, one cover to snap off. Try cleaning the lens, and mirrors, shining a flashlight straight down you can see a sort of fog on the glass. Also the white strip on the underside of the glass needs to be clean. After that you'll have to check around for a new scan assembly.
Posted on Jul 31, 2009
  • Craig Gillette
    Craig Gillette Aug 01, 2009
    Sounds like you've done it all, The main logic pcb sees those signals from the encoder, I've tried new motors and encoders with no change, Full reset sometimes wakes up the logic board again, but a logic board from a scrap machine may be your best bet...
How do I resolve the error 'failed to initialize selected scanner'?
Lift the lid as if you are going to make a copy of a document.. then whith the lid up turn the printer off still with the lid up turn the printer on and watch the scan lamp .. the light that moves when you make a copy. Verify that it lights up and moves back and forth. If it does not move back and forth the scanner lock may be in the locked position.. let me know
May 03, 2014 | Toshiba E-studio 233 Multifunction Copier...
How to fix failed to initialize selected scanner?
Lift the lid as if you are going to make a copy of a document.. then whith the lid up turn the printer off still with the lid up turn the printer on and watch the scan lamp .. the light that moves when you make a copy. Verify that it lights up and moves back and forth. If it does not move back and forth the scanner lock may be in the locked position.. let me know..
Epson gts50 wont stop scanning until paper jam occurs
I just started having the same issue. However, I don't think the problems was understood. You can one sheet of paper; that's all you need to scan. The scanner will not stop until it has cycled through 8 scans and which point it will then prompt that a e1: Paper Jam has occured. You can hit ok and still safe the document, but it is annoying have to go through the cycles or hit cancel to stop the cycling (at which point you can then still save the scan). I believe Alan and I are both looking for a solution to resolve the issue.
Mine started after a serious paper jam. I am in a rather unique situation as I have to requested elevated priveledges to down load/update any drivers. So personnally I am trying to find a way to work around the issue.
Thoughts would be greatly appreciated.
Jan 13, 2014 | Epson Office Equipment & Supplies
Bobbin Mechanism
There are two types of bobbin mechanism, rotary and oscillating, rotary goes one way and oscillating goes back and forth, if the needle is hitting the bobbin case or raceway either the needle is bent or thge machine needs retiming
Sep 29, 2013 | Sewing Machines
Cancel double sided copying
Slide the DUPLEX switch to the one sided mode on the ADF.
Also you should be able to set the single and dula sided mode from your scanning application in the setup tab.
Oct 15, 2009 | HP Scanjet 8250 Flatbed Scanner
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
Won't copy or fax, scanner failure
Uneconomical to replace the scanner assy. sorry
Feb 17, 2009 | HP Officejet 4315 All-in-One Printer
HP OfficeJet G55 All-In-One InkJet Printer Logo
96 people viewed this question
Seeker5211
Seeker5211
