Question about Tomtom GPS
My tom tom has gone blank without warning.
My Tom Tom 710 has gone blank without warning. It was working, connected to the car, I switched it off and when turned back on there is no display at all. The power light illuminates when connected to the car, however, there is no display either connected or not. In simple terms, the device will not switch on. Can anyone help?
    Problem Solver:
  • 16 Answers
Try these 3 things - wait at least 20 seconds before trying the next step:
* Reset the device, you may need to use a paper clip to do this, then try the power switch.
* Remove the SD card and re-insert it, then try the power switch
* Hold down the power button for about 5 seconds.
Posted on Jul 31, 2009
  • 3 Answers
Try reseting the device by inserting a paperclip or pin in the hole in the bottom hold in for 15 seconds. Try the power button again on top. If still no display, look real close for a really dim image (you may have to hold at some angle to see) and any starup sounds. If so, it means to device is still "alive' but the display may be bad. This is usually associated with the unit becoming too hot on the dashboad or other reason. If no display at all or sound, the unit itself has failed.
Either case is not good, it will usually require you contacting Tom Tom support for a replacement (if still under warranty) or repair. There is one other thing you can try, which support will want you to try before return. Is if you can connect it through Tom Tom Home through the computer and reinstalling the application software, if the unit is still "alive" and will connect through the usb to do so. Good luck!
Posted on Sep 13, 2009
I have tom tom one 3rd edition and am trying to fix it for a work friend anyway, it switches on but gets stuck on a blank screen after a blue loading bar has gone from left to right. i think it has been...
Check and see if it needs any update. connect it to tomtom home and that will tell u weather it has any maps loaded in it or not. Also download the available updates.
Jul 29, 2010 | Tomtom ONE 3rd Edition GPS
710 frozen on tom-tom splash screen
1. Activate the TeleType GPS program
2. Select Tools>GPS Status>Status.
3. Look closely at the GPS output that is displayed in the View Status menu. Data should be flowing even when the GPS receiver has not locked in the position.
The data string that begins:
GPGSV... is "bad data" because the receiver has not locked into the satellites.
Whereas:
GPGSA... is "good data" indicating that the receiver has locked into the satellites. Remember - "A-Okay"
4. Once the data is flowing, go outside away from buildings, select the Satellites tab (Tools>GPS Status>Satellites), and watch the satellite signal strength
Nov 27, 2007 | Tomtom GO 700 GPS Receiver
The Tom Tom screen has gone black. It worked Ok on
If I knew the model I could help you perform a hard reset as the first step to recover it. Antonio Cesar Brazil
Jan 14, 2010 | Tomtom GO GPS Receiver
Tried to update my Tom Tom One by connecting to my
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Update your device without the SD card.
Make sure your GPS runs OK without the SD card
Now re-connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options.
Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work again
Sep 14, 2009 | Tomtom ONE GPS Receiver
Hi, Tom Tom 710 has not come on for weeks.
it doesnt get better by itself. Despite having a green light doesnt mean it is charged. try changing the battery
Jul 05, 2009 | Tomtom GO 700 GPS Receiver
My tom tom 710 is dead the green light is on but nothing on it!
Change the motherboard, green light on and nothing happening is quite common, you can find motherboards on ebay for £22 +p&p.
Its quite easy to do and worth while as the 710 and 910 are still very good units.
Dec 27, 2008 | Tomtom GO 700 GPS Receiver
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Tom tom 1 4n00.012
Is the unit connect to a power cable while you're using it? Sounds like the battery just runs down. Check your power cable, is it properly connected to the cigarette lighter adapter? Maybe your cigarette lighter is defective and the unit is not gettting power, therfore running on battery all the time
Jan 25, 2008 | Tomtom ONE GPS Receiver
TOM TOM GO 700
I faced the same problem for tom tom and found that the battery had gone down. I switched it on after connecting to the power source in the Car and it was fine.
If its not battery discharge...you may have to contact tom tom support.
Dec 23, 2007 | Tomtom GO 700 GPS Receiver
GPS Logo
285 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
