Question about Comdial Unisyn 1122S Corded Phone
Caller ID Is this phone able to have caller id? It does not have it now. Can this be added? If so is this something that i can program in?
  • 60 Answers
The unisyn system needs an add on caller id module, If your system does not have that it cannot pass caller id info.
Dan
Posted on Aug 01, 2009
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
I live in the USA. My caller ID stopped displaying incoming calls. Last incoming call on the display says 12.2.14. Even when phone is ringing, caller ID does not display name, number,time,date,etc.
Call Phone Co and see if you are programed for the Caller ID feature. In some areas this feature cost more. Whether or not you are paying for it, it may not be programmed in their switch for you?
Feb 06, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
StarTalk Flash is 1.7.00 + caller ID
The Star Talk Flash is a voice mail prduct. The caller ID feature is a phone system feature. If your system is a norstar CICS or a MICS the caller ID will work only if you have the caller ID capable central office circuit packs installed. Look on the card and see if the label has "CLID". If it dose there is also additional programming required for each set under.... terminals &sets/telco features/featue assignments/show line/caller ID...set:Y. You also have to program (under sets) /telco features/caller ID: Y.
Hope this helps.
Mar 24, 2010 | NorStar M7310 Corded Phone
My panasonic kx-t7636 phone has caller id. however
you need to go to the call settings on phone and adjust the call waiting there ok
Jul 17, 2009 | Panasonic KX-T7636W Corded Phone
No ID caller displayed on the phone
Is the phone FCC approved for use in the US? Does the model purchased in Singapore use the same Caller ID algorithm as US phones? Have you tested a known good caller ID capable phone at your location to make absolutely sure the caller ID is actually turned on?
Mar 09, 2009 | Panasonic KX-TG5632 Phone
Portrait caller id
Knowing what kind of phone you have will help us find an answer.
Feb 08, 2008 | Lands Phones
Caller id
Unfortunately just adding caller ID to your phone line will not work with many business phone systems, especially older systems.
You can have this phone on one of several different Toshiba phone systems. The system must have caller ID equipment installed and programmed correctly for caller ID information to be shown on your phone's display.
Caller ID information is transmitted between the first and second ring. With business phone systems the system itself needs to collect this information and then pass it along to any phones that are programmed to ring at any given time.
Oct 26, 2007 | Toshiba DKT-2010 Corded Phone
Caller ID not working
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
Aug 20, 2007 | Avaya Definity 6408D Corded Phone
Comdial Unisyn 1122S Corded Phone Logo
254 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
k24674
Tom Chichester
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
