Continuous green flashing light
The TV is plugged into surge protector power strip. If that power goes off/or TV un-plugged there is a green flashing light on the front of the TV. I followed the manual to push the reset button, nothing happens the light continues to flash and I can't turn the TV on. Help it has been a few days now. I am not sure what my model is the guide is for Mitsubishi WD-52525. WD-52725
  • 556 Answers
Ther are some bad capacitors on the dm board in this tv, but this model is not layman friendly, we usually send in the entire chassis to Mitsubishi for a rebuild this cost about $300 then there is the cost of service also, this job will probably cost around $5 or 600 dollars.
Posted on Aug 14, 2009
2 Suggested Answers
gopakumarg43
  • 74459 Answers
SOURCE: mitsubishi wd-52725 wont turn on. no lights,
Hello
The power regulator board of your Mitsubishi TV is faulty. There are two reasons for this fault. The fist one is with its internal protection fuse, and the second one is with component failure to the power supply board. To retify this fault, for both, you must ahve its service manual to follow. User manual provides details about how to use it; where as service manual will have all the details, circuit boards, schematic diagrams, porcieedings to take out and repair the boards, components and it values etc; I can't send the service manual to you by this window. If you want to do this work by yourself, you must have it with you, while I advice you to proceed the work. To get it, you must have to buy one amoung my service published in FixYa website, or go to Google and typw my nickname "gopakumarg43" in its search box. Click on the link "gopakumarg43 - FixYa". You can access my services there. Fixya has placed me on Google, from where you can get straight to me, by mail assistance. I can't touch you by mail, as it is against our Primium Expert's rules and regulations.
The power supply of your TV should be checked. If you have knoledge in electronics and have a concept of soldering, get me by Fixya. OK.
Posted on Nov 05, 2011
HELLO MY kdf-e55a20 tV IS NOT WORKING. THE GREEN LIGHT FLASHES 6 TIMES THEN IT FLASHES RED 6 TIMES
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The Lamp light blinks when the Lamp requires replacement.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the power light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
This indicates that there is some kind of audio problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 11, 2011 | Sony KDF-E55A20 55 in. LCD Television
Standby light blinks 4 times
Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Standby time light on and keeps flashing
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
May 21, 2011 | Sony FD Trinitron KD-36XS955 36" TV
TV turns itself off and power light flashes green
May 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Green light keeps blinking will not turn on at all
May 11, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Green blinking light
Oct 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
4 fast blinking lights
Oct 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red blinking light
Aug 14, 2010 | Sony KP-53HS10 TV
Tv keeps turning itself off and then back on. green power light blinks. If i tun it off when it does that the red power light blinks 5x repeatedly.
Jun 22, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
KP57WV600 SCREEN TURNS GREEN THEN BLANK
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
Televison & Video Logo
255 people viewed this question
Top Televison & Video Experts
Electro Med Services...
