Question about Dell Latitude D610 Notebook
My Dell latitude d610 charging circuit not working on board
My Dell latitude d610 not charging it can run on charger. My battery is healthy. Computer persons said that my laptop charging hardware has to be repaired. What can i do
  • Dell Master
  • 2,404 Answers
What needs to be done is the jack that your adaptor plugs into has solder points underneath it. All the solder points need to be resoldered to make sure that there are no cracks in the solder that are preventing the jack from charging your battery.
After this is done if the laptop still isn't charging then if you know for sure your using the correct ac adaptor with your laptop then at that point the moterboard would have to be replaced.
Posted on Jul 31, 2009
  • Albert Benjamin
    Albert Benjamin Mar 02, 2011
    That is just absolutely backward troubleshooting. Why would anyone in their right mind perform a major repair (dc-Jack) BEFORE performing the LOGICAL troubleshooting action of a simple part swap (the ac adapter)? Reply
My laptop latitude d610 is not charging ples give me answer
Posted on Apr 14, 2013
    Scholar:
  • 177 Answers
Have you tried a new ,or borrowed charges.Try substituting a borrowed charger. Either your charger is bad,or the charging circuit on your motherboard is bad.I doubt if it's the charging circuit on the motherboard,probably the charger itself.
  • a jaan Mar 02, 2011
    i use wrong charger so charging circuit IC heat up and battery not charging
  • Albert Benjamin
Will keeping the ac plug connected kill my battery on Dell latitude d610?
I will suggest you to use laptop after it is full charge by removing the charger . when ever you feel battery is down then you can plug in the charger and keep using it, and when ever you see battery is full then remove the charger.
I'll not suggest you keep plugged in the charger when you are done, this way it can effect your Battery. and yes your battery can die with in a year if you are not follwing the correct way to use it.
Aug 15, 2012 | Dell Latitude D610 Intel Pentium M 1.6GHz...
Why wont my dell D610 charge i have changed the battery and charger
Hey!
If you are still encountering the problem charging your laptop's battery, it is possible that the port where you connect the adapter or the port for the battery is damaged. It will still receive power but it won't charge.
Best solution is to replace the motherboard. Just make sure you would get the exact same devices on a replacement board.
Hope this helps! :D
Sep 09, 2010 | Dell Latitude D610 Notebook
I have a dell latitude d610 that will charge fine when it is not being used. When using the laptop on the charger it will maintain the level of charge but will not charge any further
I've never owned any other laptops besides Dell, but I know each one I've had wouldn't charge either when in use, just simply maintain and maybe even drop a little of the charge, depending on what programs I'm running. When you're using your Notebook, even on the charger, it's constantly going to be using the charge that's going in and how fast or slow it's used simply depends on what programs you're running.
Aug 13, 2010 | Dell Latitude D610 Notebook
My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Feb 22, 2009 | Dell Latitude D610 Notebook
Battery stopped working
Hey,
Test your charger, the battery light blinking and the computer not starting up indicates not enough power to start up or not pluged into ac power, check the power adapter or charger. I suspect the battery is fine.
Thanks,
Ekse
Feb 15, 2009 | Dell Latitude D600 Notebook
Charging problem
It's definitely the motherboard based on the symptoms. You can send it to their out of warranty depot. Or you can purchase the motherboard from their spare parts sales dept, then look for a local tech who can install it for you.
Jan 02, 2009 | Dell Latitude D610 Notebook
Power for battery on DELL laptop Latitude D610 as posted FixYa
In the BIOS, does it show the battery and it's current state? As weird as it sounds, I've fixed an issue like this on a D600 by updating the BIOS to the most current level. Weird, but true.
Dec 22, 2008 | Dell Latitude D610 Laptop Computer -...
Dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Nov 26, 2008 | Dell Computers & Internet
Charging Problem
go back to old bios if u can
Jan 21, 2008 | Dell Latitude D600 Notebook
Dell D610 charging problem
Does it run without the battery installed? Also, will it run only off the battery? Isolate those two conditions, then we'll be able to narrow down the problem.
Good luck
Nov 20, 2007 | Dell Latitude D600 Notebook
Dell Latitude D610 Notebook Logo
898 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
