Question about Garden
It ran out of gas/then i put gas in it and it started. then i turned it off and it wouldnt start back
    President:
  • 1,776 Answers
The first thing that I would look at is a clogged fuel filter. I would also take some carburator cleaner and clean the carb. When something is run out of gas, there is usually some water and debris in the bottom of the tank that gets sucked up and can clog up the works. Hope this helped and best wishes.
Posted on Jul 31, 2009
  • 86 Answers
You might of killed your fuel pump andthat needs to be replaced for it to start up
I ran out of gas but after i put some in it wouldnt turn over so i pumped the gas in attempt to get it to start, but it would not completly turn over (all power works) then it stop trying to turn ove
that advice is true a jump start should give you enough power to start vehicle ,but the real problem might be in the fact that you ran out of fuel and have maybe tripped out a sensor , by all means try the jump start ,make sure the vehicle you use you keep that engine running with a little revving to give a boost to your vehicle, if it still wont start have the OBD codes read and cleared as the gas supply was cut may have a sensor code that will prevent starting
May 13, 2014 | 2004 Dodge Stratus
Diesel 6 0l
Every diesel has an electric solenoid that shuts the fuel off when you turn the key off. I suspect that is your problem but I don't know where it is exactly on a Ford. It should be mounted on or near the injector pump.
Oct 25, 2013 | 2002 Ford F350 Super Duty DRW Reg. Cab
Ran out of gas and put more in now car wont start i drive a bmw 3 seies
running out of fuel sucks the dirt off the bottom of the tank it might have caused it to fail i think you can get to it from under the back seat you can see if the pump has power there as well
Apr 18, 2012 | 2002 BMW 3 Series
Ran out of gas and now wont start 1994 jeep grand cherokee
check the installation of fuel injection or carburetor your...
Jan 16, 2012 | 1994 Jeep Grand Cherokee
It needed an alternator so i replaced it and then went and drove it and ran fine and then when i tried to accelerate it wouldnt it just bogged down. And then it would crank and try to start but wouldnt...
Is is possible that you ran out of gas? I would put some gas into the car, unless you are sure you got gas. in that case I would start checking for loose ground wires.
Mar 14, 2011 | 1989 Acura Integra
1997 blazer fuel pump problem.....
ya the fuel pump wont pump with the lines off but the pump is going bad they will work and wont work
Mar 06, 2009 | 1997 Chevrolet Blazer
1998 chevy malibu turned car off at gas station want start back
sounds like an antitheft system malfunction - check to see if light stays on after you remove the key
Jan 09, 2009 | 1998 Chevrolet Malibu
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
