Question about Garmin GPSMAP 376C GPS Receiver
Garmin GPSmap 376C will not boot up
The unit is brand new--used only three times and now it will not even start up. It's essentially dead.
    Brigadier General:
  • 4,090 Answers
Take it back to the seller and have it fixed. It is under warranty and any interference will void warranty
Posted on Aug 01, 2009
Garmin GPSMAP 178C not boot
can we download india map?if tell me how to download and install the map in my device Gm4300?
Nov 20, 2013 | Garmin GPSMAP 178C Sounder GPS Receiver
Gpsmap 180 firmware corrupt
It sounds like it has lost its memory battery. Usually you
would get a "memory battery low" message as it is on its
way out but you don't mention that so perhaps it has
completely failed.
The battery is rechargeable - if you leave it switched off
and loaded with a fresh set of alkalines for a few days it
may recover. If not contact Garmin as they have replaced
many memory batteries free of charge even out of warranty.
Oct 30, 2007 | Garmin GPSMAP 430 GPS Receiver
Hello.. i have a 376 C and when i start it it sais System Sofware missing.. and it dosent do anyting else
Hello
the "System Software Missing" problem could be solved by perform the following steps:-
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
If all else fails, you could always contact Garmin for help.
Good luck
Feb 15, 2011 | Garmin GPSMAP 376C GPS Receiver
376c backlight wont get brighter. I adjust the intensity anbd nothing happens
find two consecutive cube numbers or integers whose difference is a square number. i know it is 8 and 7 but hav to get the equation
Jan 15, 2010 | Garmin GPSMAP 376C GPS Receiver
Can not updait a GARMIN GPSMAP 60CSx
Try http://brilliantcorners.org/nodes/87-fixing-a-dead-garmin-gpsmap-60csx. It has helped many people. Complete steps to fix a dead Garmin are listed there.
Dec 31, 2008 | Garmin GPSMAP 60CSx GPS Receiver
GPSmap 60Csx power up problems
I had the problem where I ended up disassembling the Garmin and adding a small piece of plastic to the on/off button. For some reason the push button on the top does not reach the one on the circuit board.
Oct 19, 2007 | Garmin GPSMAP 60CS GPS Receiver
The gps does not boot
Use with caution: This will delete your user data on the unit.
Try a reset:
  • Hold QUIT pressed when turning unit ON (will delete waypoints, routes and tracklogs)
(This worked for me when I had a similar problem.)
You could try a master reset;
  • Hold Zoom-OUT + QUIT + NAV and power ON. Hold keys for 10-12 seconds.
  • You lose all almanac and temperature compensation tables (it
  • reconstructs itself but takes time - several hours)
  • Be patient - it will take HOURS for the unit to recover
Fair warning: I have not personally tried the master reset.
Oct 02, 2007 | Garmin GPSMAP 276C GPS Receiver
Garmin GPSMAP 376C GPS Receiver Logo
104 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
