How make it work try tv it work other very it works
SOURCE: JVC HR-S3901 S-VHS / Switching from TV to VCR no longer works . . .
put a tape in the vcr & press play ,if the picture still does not appear it is most likely that you have faulty cable/s(that is of course providing you have selected the vcr mode on the tv ie.rf/av)
SOURCE: emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
SOURCE: Programming RCA RCR 450 remote to work with vcr in Sharp tv/vcr combo
need programming instructions for Sanyo tv
SOURCE: Orion tv/vcr combo to work with Philips universal remote?
phillips universal remote with orion 1326 tv.
ned code
