You may not be able to get to the VM. You may have to reset the system and start over if the PW is not avaialble. I cannot find a way to reset only the VM password and retain the VM. You may want to contact NEC directly in case they have a way that isnt in the manual. The manual seem to indicate you need to reset the entire system. NEC DT300 Series User Manual To Change Security Password
SOURCE: voicemail
From an admin phone, enter the voicemail. Then select More, Mgr, ChBox, then enter the ext# you need to reset the password on. Then choose Reset Password (Select Yes when the system asks you if want to reset the password). You can access the reset extension's voicemail by entering the default code.
SOURCE: voicemail
Log into the voice mail server and you can reset the Voice mail for each account like it was a new account or you can delete the pass word on the account and then setup form the hand set. You do need to know the password to get into the voicemail server program. I believe as default it is NEC.
Actually, even as a technician, you will never know the origonal password.
But you can get in to reset the existing password back to 0 0 0 0.
There are a couple of steps; depending on your voicemail system, voicemail's are done differently, but try this first.
got to a M7310 set
-> dial FEATURE 9 8 3
-> password: 1 0 2 0 0 0 0
-> you should now see ADMIN and under that MBOX, AA, OTHR
press MBOX
-> press CHNG
-> dial the extension of the phones that you need changed
-> you should now see PASSWORD and under it RESET, press RESET (This resets the mailbox back to 4- zero's)
-> hit the * to back up and repeat fopr all the other extensions.
-> hit RLS after all is done and voila... you have now changed those passwords to those mailboxes.
Now when the new users dial F981 at their desks, and dial 0 0 0 0 the first prompt they get is pleasde change password.
SOURCE: A former employee changed the viocemail password
call your provider and have them reset it. it may also be an option when you try to call voicemail
SOURCE: I need to reset the mitel 5212 IPphone passcode as
Hello...if u have access on mitel system then u can goto user configuration form then select extension# u want to edit...from there u can even delete the mac address and more..hope it helps
