Question about Refrigerators
Fridge is 60 deg F freezer is 40 deg F turned everything up all the way yesterday and cleaned it out. Took freezer apart cleaned,put back. Cleaned drain tube, turned defrost timer clockwise till compressor started. saw no ice anywhere, didnt damage anything, getting a skin of ice on a test bowl of water in freezer, fridge still over 50 F.
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Jul 31, 2009
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
I am having trouble getting new fridge cool enough in fridge. Should it get below 40 f in fridge on mid setting of both freezer and fridge section
fresh food tempt should be 38 deg ( this is good ) and 40 is close . as it will be 5 deg up and down freezer thempt should be around 5 to 15 deg or ice mker will not work . make sure the coils ore clean and fans are working or these tempt can not be obtained . mm feed back pls
Jan 01, 2011 | KitchenAid Architect Series II KSRG25FVMS...
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Side by side is not cooling. I believe it is the defrost heater, how do you replace this?
The defrost thermostat is located behind the freezeer firewall, on top of the evaporator.
It is part 240 on the diagram below:
Regards.
G.
GE refrigerator works intermitently
change the thermostat my dads fridge did the same
Aug 11, 2009 | GE Refrigerators
Refrigerator running. freezer will not go below 40
you need to clean the bottom of frige of dust and water there ,, and if that dont work clean pipe that goes up the back of frige
Aug 10, 2009 | Refrigerators
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Temp problem. freezer temp 0 deg. fresh food 46 deg.
An hour aint enough. Turn off fridge, use blow drier, thers a huge ice cube behind that sheetmetal wall back of freezer inside wall, it takes 48 hours at 75 degrees to let it do itself. Listen for inside motor, its obvious. If so, you hve a defrost problem.
Mar 12, 2009 | Refrigerators
Kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Nov 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
