Question about GWC (KS-102) (ks102) 2-port KVM Switch
When I enter BIOS on one computer, no keyboard. The other computer is OK Otherwise both computers work fine in all modes. Only when in BIOS on computer number one.
  • 1 more comment
  • redblanchard Aug 01, 2009
    Maybe I wasn't specific enough about my problem.
    The switcher works normally when I am booted up into windows, the only time it fails is when I enter the BIOS and attempt to make changes. However I will double check the bios and make sure the PS2 keyboard is enabled. It must be though, because it works fine once I am in Windows.
  • redblanchard Oct 21, 2009
    My original problem was with another KVM switch. When I bought this one pictured, no more problems. It does have heavy cables and the PS2 cables should be longer than the Video cables, but they are not.
  • 3,051 Answers
Hello there:
first try this boot the computer and go to device manager uninstall the keyboard and than click on view and than click on scan for changes and see if the computer will recognize the keyboard and reinstall the driver for the device and if this doesn't work.. boot back into bios and check the settings for plug and play and make sure that this is enabled and if this is a usb type keyboard make sure that the usb setting is enabled than save and reboot you can also use computer #2 to check the settings against computer #1 to find out if you have any thing set differently ok?
please try these ideas and see if they work
best regards mike
Posted on Jul 31, 2009
Stuck on bios screen
does your keyboard work on the computer you might try another keyboard before trying anything else
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
make sure the usb lead has a secure dust free connection if applicable
disconnect the keyboard restart your computer then reconnect it the found new hardware wizard should activate
if this does not fix the problem
restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
hope it helps
Jun 13, 2012 | Gigabyte Computers & Internet
Cant open bios ,pressing the delete key to enter bios does not work locks up.
this might be a problem with your keyboard make sure the keyboard lead is securely seated
or if its a wireless the usb device is
or if this does not fix the problem
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Click start control panel keyboard you can change your settings there
click start control panel administrative tools computer management device manager scroll to keyboard you could see a yellow/question exclamation mark? ! or a red X right click to install drivers
click start control panel keyboard hardware then properties you should see driver details and have options to,update driver,roll back driver,uninstall
if your computer came with a motherboard disc the drivers could be on it
hope this helps you
Oct 02, 2011 | AOpen AX4C Max (91.8AU10.201) Motherboard
Cannot start bios even when presssing delete
make sure the lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the usb port (if applicable)
the restart your computer again during the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Aug 27, 2011 | ASUS K8V-X Motherboard
Display don't comes back after LCD goes to Standby. Moving the mouse or pressing keys in keyboard don't work at all to return the display, but the tasks(if downloading or copying etc) are...
have you tried pressing the F4 key or the shift key after stanby mode
you might have to uninstall your keyboard restart your computer then reinstall it
click start control panel administration tools computer management device manager scroll to keyboards you might see a yellow exclamation or question mark or red x you will need to update driver right click to update driver
if your computer came with a motherboard disk the drivers could be on it
or restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
or you could restart you computer you will see on the scree to press a certain key to enter set uppress and hold that key to enter BIOS you can load failsafe or optimised defaults
hope this helps
Aug 13, 2011 | Intel DG45ID Motherboard
My R31 Think Pad was running very slow and trying to fix this problem a technician istalled a new version of Windows XP but the keyboard is disconfigured now since some keys do not correspond with what is...
Troubleshooting keyboard issues ThinkPad Lenovo Support US
Internal ThinkPad Keyboard
Power on your computer. At the BIOS splash screen, press F1 on your internal keyboard. You should see a message "Entering System Setup." If you are able to enter BIOS, make sure that you can navigate through the menus to ensure basic functionality. While there, press the CapsLk key and ensure that the indicator light turns on or off.
If you are not able to enter BIOS, try pressing the blue ThinkVantage button or press the Enter key.
Boot into your operating system. Click Start, point to All Programs, point to Accessories, and then click Notepad. Using your internal keyboard, press each letter key and each number key to determine if your keystrokes are being recorded properly. If certain keys do not work, make note of these.
Check to see if you have installed any keyboard mapping software that would be interfering with normal keyboard functions.
Boot into Windows Safe Mode and test keyboard functionality with notepad. Please refer to step "B" above.
Windows XP Safe Mode instructions:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/boot_failsafe.mspx
Windows 7 Safe Mode instructions:
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Verify that the latest BIOS for the ThinkPad system is installed.
Click here to view the latest BIOS files for all ThinkPad systems.
Reseat the internal ThinkPad keyboard, if applicable.
If the keyboard is a customer replaceable unit (CRU), then reseat the keyboard connector. Please verify this in your system's Hardware Maintenance Manual.
If these steps have not solved your problem:
Refer to "Need more help?"
External USB Keyboard
Ensure that the keyboard's USB cable is securely installed into your ThinkPad.
Remove the keyboard's USB cable from your ThinkPad and install it into a different USB Port.
Power on your computer. At the BIOS splash screen, press F1 on your External keyboard. You should see a message "Entering System Setup." If you are able to enter BIOS, make sure that you can navigate through the menus to ensure basic functionality. While there, press the CapsLk key and ensure that the indicator light turns on or off.
Try entering BIOS with your Internal Keyboard.
Boot into your operating system. Click Start, point to All Programs, point to Accessories, and then click Notepad. Using your External keyboard, press each letter key and each number key to determine if your keystrokes are being recorded properly. If certain keys do not work, make note of these.
Windows XP Safe Mode instructions: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/boot_failsafe.mspx
Windows 7 Safe Mode instructions: http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Jun 09, 2011 | IBM 02K6212 for ThinkPad R31 Series...
When starting my computer I get a BSOD That Tells
The BSOD screen comes up mostly due to hardware problem. The BIOS of your system unable to initialise a hardware from a particular location.
You mentioned that after re-booting the system works fine with the keyboard. That shows that some hardware conflictions are there in your computer.
Do This:-
Make sure that the computer is connected only with the keyboard,mouse,monitor and the internet cable.
Now,
In the normal mode click on start-->run-->cmd
-->type chkdsk /r and now hit enter.
The black screen gives you a message saying
Chkdsk cannot run because the volume is in use by another process. would you like to schedule this volume to be checked the next time the system restarts. (Y/N)
In this case press Y and hit enter.
Now when you restarts the computer the check disc will start automatically and will take some time to scan your computer harddrive.
Now when the this process is over.
Insert the windows Operating system CD in the computer and then run a scan disc on the computer.
To run scan disc do this:-
Start-->run-->type here sfc /scannow and hit enter.
This will update your windows DLLcache dll files.
now restart the computer.
Now you can connect all your devices which we have dissconnected the first time and then restart the computer again.
The problem should be resolved.
If still you get the BSOD screen let me know if you have made any hardware changes recently..!
May 10, 2010 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
I cannot use my keyboard and mouse. Something is wrong with my devices
Make sure the keyboard is working in bios. When you boot the computer hit f2 or Del. key to make sure the keyboard is working. Also make a note that the keyboards light blink while turning on the pc.
If you are able to go to BIOS that means the keyboard is working fine.
Boot your computer in safe mode by tapping F8 key while the computer is booting. Select safe mode and check if the keyboard and mouse is working in safe mode.
If it is working in safe mode. Do a system restore to a date where everthing was working fine.
Please revert with the result of above .
Sep 01, 2009 | HP Computers & Internet
Keyboard not working only during booting
If your keyboard is USB, switch to a standard PS/2 keyboard, and enable legacy support for USB in your bios.. This may help you, but your bios may not be able to use a USB keyboard during POST.
May 31, 2009 | Intel Motherboard
Boot Up Problem with Eclipse II Keyboard
If you have a newer system you can enable USB legacy support via bios and your new keyboard should work fine, otherwise, your keyboard will only work once the operating system is booted up.
Nov 16, 2007 | Saitek Eclipse II
Keyboard not detected
There are some steps to figure out what is causing this.
If you have a desktop:
1. Replace with another keyboard that you know works.
If it boots, than it is the keyboard that was bad
2. If it doesn't - try getting into bios. There is a secion for
keyboard and make sure it is enabled.
3. If it is enabled, than it would be the port for the keyboard that
is the problem. You can take the computer apart an replace
it, or take it to someone who can fix.
If you have a laptop:
1. Add a keyboard to the computer.
2. If it boots, than it is the keyboard on the laptop. This could
mean it is not connected, you have the wrong drivers, or
try getting into BIOS like #2 above.
3. If the keyboard is enabled in the BIOS, reinstall drivers
first. If this doesn't work than there is something wrong with
keyboard (follow #3 above).
(BIOS - when computer boots up, look closely. There is a button you must press to get into setup mode (BIOS). I press F2 on my computer to enter BIOS. Some computers are different).
Nov 09, 2007 | Logitech S 510 (967555) (DH967555)...
GWC (KS-102) (ks102) 2-port KVM Switch Logo
75 people viewed this question
Top GWC Computers & Internet Experts
David Payne
David Payne
Are you a GWC Computer and Internet Expert? Answer questions, earn points and help others
