Question about YouTube Videos
You tube videos run foe 2 seconds & stop for
You tube videos run for 2 seconds & stop for 15 seconds
    Problem Solver:
  • 7 Answers
Sounds like a bandwidth problem -- a slow internet connection. The only other time I have seen a problem like this was when there was an issue with the motherboard, video card or sound card -- depending on the type of machine you have. To prove there is no issue with video and sound, place a dvd into the machine and ensure that runs properly. Assuming it does, then chances are you just have a poor internet connection.
Posted on Jul 31, 2009
  • 724 Answers
The buffer is being filled while you watch if you run a DSL highest speed TI or T2 line it will stream faster Dialup it may take days
  • tommya300
    tommya300 Jul 31, 2009
    And what might you say your op sys may be
Where is the blower motor in a 96 camaro
Open the glove box
Squeeze the tabs & drop door down
There it is-so it says on the internet
You need to use Google differently & You Tube Video
My wife finds things 15 seconds
I find 90% of all the questions on this FIX YA site in
a couple minutes
Aug 13, 2014 | Cars & Trucks
Tip
LED Tube replacement for 48
These are better, but cost more. Get them at Amazon where some reviewers complain about quality. I love them in our garage where I replaced 4 tubes in 2 fixtures. Took an hour with the first, 30 mins for the second and probably 15 mins if I did another. Here's a link to an Australian teardown video. Eliminates mercury concerns.
on Dec 07, 2013 | Sli Lighting 48" Fluorescent Tube Bulb 32...
My dash lights stopped working right after a stereo was installed. What fuse is it. And where is it located? Does it matter what amp I put in it it calls foe a 15 amp but I used A 20
Without knowing what kind of vehicle you have, just pull out all the fuses 1 by 1, untill you find the blown one. I would stick to what the factory calls for. Using a higher rated fuse runs you the risk of melting the insulation off your wires, and a high risk of fire.
Dec 04, 2013 | Cars & Trucks
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
I have a AMH95 gas fired furnace. there are 2 drain tubes on the back of furnance that drain water when the central air is running. One tube runs to a tube that runs to a floor drain and the other just...
Hello RR,there are 2 tubes one is the PRIMARY drain & the other is secondary drain.If the primary drain becomes CLOGED or slows down the 2nd drain leaks.Its time to clean out the primary drain tube.Find the end or disconnect it & blow/flush it out to clear it.
Aug 09, 2010 | Heating & Cooling
When i go on you tube or try to down load any video and play it the video skips and stops (video stops) starts again but never plays all the way through without some tpye of interuption. when the video...
hai from your mail i have understood that you are having some troubles on playing clip that is downloaded from youtube.i thing flash player 10 that you use will not be installed properly.kindly check your instalesion progress and reinstall it.hope the provided information is help full.thank you for contacting FxYa.com
Mar 21, 2009 | YouTube Videos
Armstrong v tech 91 furnace. will not make heat. when on unit runs continuosly no matter what thermistat is set at. could mother board be bad,replaced once already. cah this be done by the home owner to...
These furnaces goes thru 4--steps for complete run time.... step-1, the small draft inducer blower motor blows and prove thru the small air tube that sucks a switch close to tell the circuit board to go to step-2......the glow plug glows for 15 seconds and step 3 the gas valve opens and dump gas in the venturi tubes and lights off the glow plug and proves thru a flame sensor (pin with 1 electrical wire connection) on the last venturi tube which tells the circuit board to go to the last step 4--, to turn on the main blower fan after 90 seconds!. Where ever it stops at then thats where your problem is!
Sep 12, 2008 | Heating & Cooling
Hafler power amp has one side out. Would like local repair.Series 9300.Approx.10-15 years old.Not used much.Second time to blow.Runs 4, 8om speakers including 2 bose 802,s (no bose controller or eq in...
just discovered same problem with my Hafler DH-200...right channel out but no obvious problems inside (no loose/burned wires, components, etc). Driven by Hafler pre-amp, but definitely power amp problem.
Sep 03, 2008 | Audio Players & Recorders
Sharp r95 combination oven only stays on foe 1m before switching itself off
Check the damper motor - this closes a small metal door usually located behind the magnetron tube. If the unit runs exactly 59 seconds then cuts off, then that's most likely your problem.
Jun 30, 2008 | Sharp Microwave Ovens
Cornea 15" monitor
If possible, try a new video cable. If it does not correct itself with a new cable, the problem is not serviceable. Flat screens do one of three things: inverter will go out (no light), line input board signal failure and power supply low volts on 12v B+.
Mar 28, 2007 | Cornea CT 1503 (Black, White) 15 in. Flat...
YouTube Videos Logo
224 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
