Question about RIM BlackBerry Bold 9000 Smartphone
Type "a" get up, trackball enter, get L or M
Hi, my phone fell in water and now I can't type the "a" and the track ball can not be used as "enter". Can you help me?
    Problem Solver:
  • 16 Answers
Send the phone to me, i can fix liquid damage. it'll cost 55 dllrs plus shipping to my address. I will ship it back free. e-mail me at cellsolutionsmcallen@yahoo.com
Posted on Jul 31, 2009
My trackball doesn't move down on my8310 blackberry
Chances are it's just clogged with dirt
Ok. Follow this carefully cause more people break and destroy their trackballs by not following directions step by step
Carefully pry the grommet (ring around the trackball) off and set it aside. If you look at it. There is supposed to be only 3 pins. NOT 4 so if you have 3 your fine.
Carefully tip the phone over and tap it if you have to, to get the track ball to fall into your hand.
Then I suggest taking a cotton swab, and some alcohol, dip the swab.
Then run it all over the ball as you move the ball in all directions and free up what ever is in there, ie; dirt, dust, stuff from your hands...
Once the track ball can move in the down position or in a complete circle without any problems. Let it dry for like 5min.
Drop it back in carefully. Direction of the trackball doesn't matter. Then carefully put the grommet back in the exact way it came out.
Then it should work just fine.
I've used alcohol to clean mine many many times and never had a problem. Alcohol is different that water, it evaporates and doesn't leave a film or damage.
I hope that helps.
Aug 11, 2011 | RIM BlackBerry Curve 8310 Smartphone
How to clean the trackball
Remove the plastic ring, remove the trackball and submerge it in water... then DRY it really good...
Jun 03, 2010 | RIM Blackberry Curve 8300
My BB Pearl 8100 tracj ball will not select when I
The trackball dome and/or module is bad. Try www.bbmedic.com
Dec 12, 2009 | RIM BlackBerry Pearl 8100
Blackberry curve got wet
yes..
if nothing is working, then you need to go to your carrier and either get it fixed or they might replace it... dont tell them its water damage though.
Jun 10, 2009 | AT&T Blackberry Curve 8300 Smartphone
Keys Not Working after Water
there is an area under the track ball that goes bad if it get's wet. Cleaning that area with a brush can sometime get it up and running again. If you're out of warranty try to remove the trackball and clean the area below it if necessary. There is a Blackberry Repair Guide that shows how to open a Blackberry and remove the track ball yourself.
May 28, 2009 | RIM BlackBerry? Pearl 8120 Cellular Phone
The tracking ball rotates but it does not move over the icons on the left side. Is there anything I can do to fix this?
Depending on how comfortable you are with removing the trackball it's not hard to fix... you may have some dirt or grit interfering with the trackball and/or sensors. Take a small screwdriver or blade and gently pop the silver ring around the trackball off. This will free the actual trackball housing. Use an old toothbrush to clean everything. I also soaked the trackball in a little rubbing alcohol. Just make sure it is completely dry before reassembling. If that doesn't work you can purchase replacement trackballs from places like crackberry.com.
Apr 18, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
The track ball on my blackberry 8310 stopped working.
No, but fortunately the trackball is not hard or expensive to replace. If you are technically savvy you can do this yourself. Just purchase a trackball on the internet. The trackball easily comes off if you put a small flat screw driver under the outer side of the chrome ring and pull if off. Let me know if you needed more help. Good luck
Mar 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
The ball won't scroll down
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Blackberry pearl
First, turn off the device. While pressing down firmly on the track ball roll the ball in all directions.
If that doesn't work, then you may need to take out the track ball and blow it out with compressed air. The link below shows how to disassemble the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 01, 2008 | RIM BlackBerry 8700c Cellular Phone
Track Ball
Your track ball may simply be dirty. Get a q-tip wet with rubbing alcohol and rub your track ball and repeat until the q-tip stays clean. Hope this helps!
Jul 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
RIM BlackBerry Bold 9000 Smartphone Logo
237 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
