Question about American Standard Reminiscence 2908.020.178 Black Slipper Soaking Bathtub...
How to clean out jacuxxi bath pipes
Hi!
When I put the jets on I get black bits in the bath. I know they need cleaning but how do get the solution into the pipes, as there is no filter and the pipes are not accessible as they are in the wall.
Any ideas, I'd really appreciate it
  • 123 Answers
All Jacuzzis have a suction fitting. I do not which cleaning solution you are using but most require that you fill the tub to at least 4-6 inches above the suction fitting (some require hot water and some don't specify) then add the appropriate amount of cleaning solution and then for a specified period of time. The suction fitting is the only way to get the solution into the piping; unless you have a professional plumber do it. If you have any questions please ask.
Thx
Posted on Aug 01, 2009
We have gunk coming from the jets when powered on - What's the best way to clean this tub so we can actually use the jets?
You need to use them on a regular basis. Put as little water in the tub as you can get away with and then add some bleach. Run the bath jets for 15 minutes to clean and sterilise it. Empty the bath and fill it again with plain water. to rinse it.
Feb 25, 2018 | Jet Home
I want to clean the jets in my tub they look mouldy
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link at the bottom to the cleaning products I can find right now. There may be others out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Feb 27, 2014 | American Standard 9330.014 Adhesive Bath...
Get jets unplugged
Cleaning your Tub
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Jan 19, 2014 | Whirlpool Home
My Royal bath tub leaves residue each time I use it. How can I stop this
US Parts Center
Oct 18, 2013 | Whirlpool 5"x36" White Bathroom Drop-in ...
I need to know how to clean the jets in our eljer spa tub
Cleaning your Tub
US Parts Center
Oct 04, 2013 | Eljer Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
Black soot in my jacuzzi tub
sounds like the rubber seals are going bad, does it recomend to run cascade thru the jets? this might be harmful to the gaskets and the pump, you maight want to disconnect the hose and flush out the tubes going around the tub, but I would call jacuzzi and ask them if this is good to run thru there, thye might be able to help you with the gaskets, questions over the phone do not cost you, call them, ask for repairs section good luck
Feb 27, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Spa bath which spits black bits out when put jets on - tried milton and dish washer tablet
This is due to bacteria in the water lines. this happens when the tub is not used every couple of days. The dirty bathwater dries in the water lines and festers while not being used for days (weeks) later. You should use a good cleaner through the pipes at least once a quarter or better yet once a month. This a link to an awesome product. System Flush
Feb 24, 2009 | Home
Lost jet clean charger for philips architiect
Hi, it may be worth your while looking at e-bay to see if anybody is selling a broken shaver with all the bits still working, You can usually pick things up that way, plus, they are often Very cheap! Best of luck, Nick.
Nov 09, 2008 | Norelco Arcitec Electric Shaver with Jet...
American Standard Reminiscence 2908.020.178 Black Slipper Soaking Bathtub... Logo
169 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
