Question about Hitachi EC119SA Twin-Stack Air Compressor with Control Panel and Couplers
Keeps turnning off breaker - Hitachi EC119SA Twin-Stack Air Compressor with Control Panel and Couplers
  • David Shaub May 11, 2010
    How many amps does it draw at the MAX? What is the breaker rated for?
    Scholar:
  • 113 Answers
You may want to look at the circuit you are plugging this into. This may be pulling a load that is to much with everything else on the circuit and causing it to trip. Try to plug it into a bathroom circuit which should be rated at 20 amps and be of 12-2 wire and see if it trips that breaker or GFI. Let me know and I can help you from there.
Posted on Jul 31, 2009
I have a breaker that keeps tripping and when I have my washer that is on a diferent breaker, on and I turn on the 20 amp breaker in question, my washer sounds like I am shooting 220 into it
breaker problems especially ones that are connected to something that causes shocks should be investigated by an accredited electrician immediately and certainly not after months or just left off
Imagine how you will feel if some child unknowingly turns on the equipment and gets shocked
It a 10 amp breaker trips it is because of a problem in the washing machine
If a 20 amp breaker trips and still produces noises in a washing machine I would be pulling the plug on the machine until I had it checked out professionally
As I have said , the wiring in the premises needs to be checked professionally first and then have the machine checked by an accredited service technician
Remember your next shock could be your last
Jan 26, 2016 | Electrical Supplies
Reset Jandy PS6, still flashing red and green
turn off heater if ok then replace ignitor if not keep removing auxs until stops blowing breaker
Apr 02, 2014 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Electronics breaker keeps tripping switched
write down all auxs then unplug all then turn on and plug one at a time till it pops probably heater ignitor if ok bad pump motor
Aug 18, 2013 | Pentair Intellitouch Power Center Includes...
One breaker is popping what to do
You have a wiring problem on that circuit. The circuit is doing it's job. Call a qualified electrician.
Apr 22, 2013 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Furnace keeps tripping the breaker changed breaker and wires all good up to the furnace still keeps tripping when i try to turn power on. nothing happened to the furnace and the wires were tested up to the...
Disconnect the black power wire where it is connected to the furnace with breaker off. Put a wire nut on it and then turn the breaker on. If it continues to trip, the problem is not the furnace and you will have to trace the power wire back to the breaker box to find problem. Next, disconnect the black wire from the breaker (with breaker off) and then snap breaker on. If it trips, bad breaker. If the furnace was disconnected and breaker did not trip, you have a short either on the P C Board or the transformer.
Mar 31, 2011 | Heating & Cooling
We set our wall oven for self-clean and received an error message after about 4 hours that told us to turn off the circuit breaker. We are unable to turn the circuit breaker back on again.
If you cannot turn the breaker back on then it is no good...some breakers do take some very firm effort to get them to come on...but the oven may have ruined the circuit breaker...
Circuit Breaker Keeps Tripping
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 26, 2010 | Thermador SC302T Electric Double Oven
It wount turn on it keeps on switching off how can i deeal with this
Take the wire of the breaker, try turning it on, if it still won't turn on the breaker is bad. But if it works without the wire on it you have an issue with the wiring. BE CAREFULL!!!
Nov 28, 2010 | Your One Source Square D #HOM 115CP 15A SP...
The hottub keeps kicking the circuit breaker off.
Either the breaker is bad or you have an electrical problem. Unless you know how to work with electrical problems call for service. If you unplug the hot tub and plug a lamp or hair dryer into the outlet does the breaker trip? If yes, call an electrician. If the outlet is fine call for service on the hot tub.
May 01, 2010 | Home
Fan is set in auto position but keeps running
Hi Patsy go to circuit breaker panel and turn off breaker to blower unit.Count to 5 and turn back on.I hope it is labeled which breaker.
Apr 01, 2010 | Friedrich M18CF Split System Air...
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
Hitachi EC119SA Twin-Stack Air Compressor with Control Panel and Couplers  Logo
334 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
