Question about Remington HC-912 Hair Trimmer
HC900 really. I'm trying to reassemble the blades, but the ridge (triangular profile rod, looks like hard rubber) that fits the groove on the bottom blade is spring-loaded, and I can't keep it down to fit the top blade on. How do I hold the ridge down, fit the bottom blade on AND fit the top blade long enough to tighten the screws?
    President:
  • 2,976 Answers
You have something in the wrong place. The blades should lay against each other.
Posted on Jul 31, 2009
I have a set of JBL TR225 I need to take one of the woofers out but cannot figure out how to disassemble it. It has no screws to support the grill or the back side. Any info are links you can give me will...
Often there are small screws retaining the grille... sometimes they are black and hard to see. Other times the grill sits in grooves at the side and one has to "buckle" the grill outward to disengage the edges from the grooves. Sometimes the metal grille has rubber strips at teh edge and when reassembling, they need to be restored to the grille before it is "buckled" to get it back in the grooves. One needs to use a medium sized flat bladed screwdriver to pry up the middle of the grille at one of the two free sides and get it out of the grooves.
May 06, 2011 | JBL Bags JBL Sub Transporter Case Speaker...
CHANGING REAR WIPER ON 2008 OUTLANDER
These are available at the dealership. There is one way though. You can get a 21" RAIN X wiper and i just cut it down to size. The grooves on a RAIN X will fit up to your rear wiper. As far as replacing it although it looks more difficult at first glance it it every bit as simple as the front wiper blades. It's a simple pop off. You can also just change rubber wiper and leave the actual blade alone. the rear is a mini blade style (this refers to the size of the rubber insert in the blade, not the actual whole blade being small.) You can replace the rubber using an Amcor blade or any "mini" blade. Puchase the biggest one they have, take out the rubber wiper and just cut to size. You can change the rubber many times off of one blade thus saving you a bunch of money.
Mar 17, 2011 | Mitsubishi Outlander Cars & Trucks
Even though I clean and now have started to spray silicone on the end, the paddles and etc. get stuck and are hard to remove. What can I do to stop this?
Hi GMVLAHOS. Sorry to hear about your difficulties with removing your mixing blades. By the description of the symptoms, I think that the ‘groove pin’ (the pin sticking out from the agitator shaft that locks your blade onto the shaft) has loosened and shifted out or bent (or both) and this may be the cause of your difficulty in removing your mixing tools.
The ‘groove’ pin is supposed to be tightly fitted to the agitator shaft but it is possible, over time and use, that it has loosened and shifted or bent to the point that the mixing blades ‘appear’ to be stuck and doesn’t come off easily. A quick inspection of the agitator shaft as well as the blade attachment wells can confirm the diagnosis.
Inspect the opposite side of the groove pin hole on the agitator shaft. The end of the groove pin should be flush (or very nearly flush) with exterior of the agitator shaft. If there is a significant space then the groove pin has started to come free from the agitator shaft. The groove pin will still remain in place but the clearances between the pin and the blades may be reduced to zero, making the blades ‘stick’ when you try to remove them.
Also check the blade and see if there might be some additional scouring inside the attachment well where the groove pin contacts the blade when you mount or remove the blade.
How can you fix this? If you are DITY type person and feel adventurous, and if the groove pin does not look bent then a couple of light blows with a small hammer and punch should drive the pin back home tight. If the pin looks bent, then you would need to replace it. To remove the groove pin, you’ll need a small diameter punch (smaller than the diameter of the groove pin) to drive the pin from the agitator shaft.
You will need the Parts List manual on hand. If you're lacking one, you can download one from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW select Parts List (1), K45SSWH0.pdf (341.41 KB), and then check to see it this matches your mixer model.
Turn to pages 4 & 5, titled: Case, Gearing And Planetary Unit for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 21, Groove pin in Illus No. 26, Agitator Shaft Assembly. The groove pin is what needs to be replaced.
Here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; and partstore.com. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Dec 17, 2009 | KitchenAid K45SS Classic Stand Mixer
I hear a high pitch squeal some times when its running a normal cycle????
hair or wire or wrapped lint around the blades that grid the food. Had to dissassemble from inside the unit, pull out blade, remove hair, reassemble - really hard. Get the rubbers just right. It's a 30 min job yourself. just start pulling out all the screws around the bottom on the inside.
Oct 05, 2009 | LG LDF6810 Built-in Dishwasher
Wahl 8550 Pet Clippers Won't Work
Tried the above solutions but it all keeps falling apart. It's a wahl pro series rechargeable. There are two screws, large blade, small blade, white plastic part and a silver bracket that seems to slide on the white plastic part. What goes in first? How do I assemble it? How do blades match? Do the grooves on large blade fit into small blade? Help, I can't reassemble it. Thanks in advance! Pam
May 06, 2009 | Wahl 8550
Don't know how to replace the wiper blade for honda accord, 1997
hi from uk have come up against this problem on hondas and if you wish ? you can replace the wiper rubbers as i have done by going to halfords or other motor supermart and purchase the rubber/blades either same length or longer ? then remove the steel blades from each side of the rubbers on wipers by pulling from bottom whilst flexing the wiper clear ok? then pull out the rubberblade with patience you can easily feed new rubber into w/blade /make sure you insert right way ie there is a notch in rubber that goes to top look carefully ? then re fit steel blades one at a time into grooves in rubber making sure the top locates into notch in rubber job done ! and huge saving on having to buy complete arms and blade in uk rubbers approx £4 a pair ps if you get the longer rubber you can cut to same size as old b4 fitting hope this helps ?
Jan 01, 2009 | Honda Accord Cars & Trucks
Stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Dec 27, 2007 | Cuisinart DLC-5 Food Processor
Dishwasher repair
newbury, the screen should set in the grooves on the bottom. The chopper blade that fits on the shaft should have a small hub that fits over it. If you look on the housing cover (inlet protector) you will see a channel that slides over the end of the chopper blade shaft. This secures the chopper in place. Catriver.
Mar 06, 2007 | KitchenAid 24 in. KUDP01DL Built-in...
Replacing belt on bread machine
Where did you get the replacement belt ? My brother is looking for a belt for a similar model K6761 which uses the same belt (I think). It is about 24" around and 1/4" wide. It has (3) grooves inside and the backside has many notches. The motor has grooves, it would go on there. Where did you get the replacement belt ? thanks regus_patoff_2000@yahoo.com
Feb 02, 2007 | Regal Ware K6725 Kitchen Pro Bread Maker
Remington HC-912 Hair Trimmer Logo
249 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
