Question about Amana Refrigerators
Ice maker does not work. We think it's the motor How much to replace? Model TSI18A5
    President:
  • 704 Answers
I believe that this has the factory installed ice maker, which means that it has the sealed motor assembly. Which means you might not be able to get just the motor for the ice maker.
Here's a link to searspartsdirect.com with the breakdown for the ice maker. I'd suggest you call the parts service number and see if you can get them to provide you with the part number for the replacement motor assembly, as it's not listed as an available part, but that doesn't mean you can't possibly get one.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=TSI18A5L-P1188201WL&productCategoryId=0166000&brandId=1268&modelName=Top-Mount&diagramPageId=00011&componentDescription=FACTORY%20INSTALLED%20ICE%20MAKER&documentId=I2203250&backToLink=Return%20to%20Sub%20Components%20list
Hope that helps and best regards!
Posted on Jul 31, 2009
Why does my control panel show er 1f
Had the same problem with my Kenmore Elite Series Refrigerator. Upon searching for the answer the closest and simplest answer was a faulty fan specific to the ice maker compartment. This fan is suppose to regulate the humidity in the ice maker, but sometimes the humidity becomes too high and that causes the fan to freeze. (A tell tell sign is when your Ice Maker shoot freezes up, or water begins to drip from the Ice Maker and puddles up in the catch tray or on the floor in front of the Refrigerator). When the fan becomes frozen, that causes the 1F error display to come on. There was also a second reason that was consistent with a faulty circuit board, but that did not match as closely as the faulty fan.
Most answers directed you to replace the fan...but I gave this a try first, and by the way my option has solved my problem fan for over two years now. Simply .. open the refrigerator door and turn the Ice Maker off. Then take the ice tray out and dump any remaining ice and clean and dry off the tray and the ice shoot that the ice drops through into your glass. Leave the Ice Maker off for 3-5 days, giving the fan enough time to thaw and dry out. You will have to live with the inconvenience of no Ice Maker for that amount of time .. but you can do that rather than paying an enormous fee to have it serviced in home (unless you're still under warranty). After 3-5 days has expired simple turn the Ice Maker back on. If by any chance this doesn't work..try it a second time but leave the Ice Maker off 5-7 days. Honestly, this should solve the problem. Mine is still working flawlessly. God Bless
Dec 17, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Profile Model PSS26LGSC Ice maker not working
Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
Apr 07, 2013 | GE Refrigerators
Ice maker stopped working...water works, ice tray has water, ice maker is turned on. curious if I should just replace the motor or if it could be something else
If your ice maker is not making ice and you poured water into the ice maker, that would indicate the ice maker is not cycling. If you have any make or model except a whirlpool, kitchenaid or sears kenmore, if you replace the ice maker, you will be making ice in no time. If you have one of the aforementioned brands, AND the ice BUCKET is mounted on the door, you will have to replace the electric eye boards on either side wall as well, as these often short, damaging the icemaker electronics in the process.
Nov 09, 2010 | Kenmore Refrigerators
It is a Kenmore Coldspot (Whirlpool) side by side model # 106.57024601 a repairman replaced the ice maker circuit board which had shorted from washing the outside of freezer door with spray cleaner....
its a tuff call but i think if the board has been replace and the motor runs then ck the touch panel that selects reg or crushed . . and if it is the board that has been replaced re ck all the connections .. mm
Sep 24, 2010 | Whirlpool Refrigerators
I have an old U-line ice maker. I can not find
The mechanical parts of those models is the same as a BI 95 or BI98. If your looking for the faceplate that would be part number 150. This includes the timer motor,gears,water switch, and hold switch. You can order this thru a parts distributor. Appliance Parts Depot or All Brand Parts should be able to help. If you want to replace the complete icemaker assemly that part number is 402
Jul 04, 2009 | U-Line Icemaker
Refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnnmbnm
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker Dispenser is not working.
thanks for the question looks like the ice maker does not cycle there is a electric motor that turns on to drop the ice seems like that doesnt work looks like you need a new ice maker Thanks for the questiuo The appliance doc
Sep 11, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
Ice maker LG side by side
What is the model #? Get it off the sticker inside the refrigerator side.
Oct 08, 2007 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
75 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
