Question about Mountain Home
What type of waste water treatment is the best for mountain toilet?
  • mehriahmadi_ Jul 31, 2009
    which type is suitable for mountain public restroom with 500 user daily?after treatment discharged can go to river.why suggest holding tank?
    President:
  • 2,976 Answers
Since there are variables you don't mention, the best is a holding tank. Have it pumped out.
Posted on Jul 31, 2009
How do I stop my toilet tank from releasing water into the bowl for a few seconds every minute or so?
Most commonly it would be to replace the flapper. It sits at the bottom of the water tank and is what allows the water to flow when you flush the toilet. On a standard toilet, there is a chain attached to it from the handle. Attached photo are common as well as not so common type. Best to look at yours and buy the same type so you can easily snap the old one off and the new one on.
In the intern, you can try to clean the old one...the rubber starts to break down from the chlorine over. Just turn off the water valve, drain the tank (flush) and gently wipe the edge of the old one. Replacement is just as easy, drain, remove old chain, remove old flapper, reverse install. Just pay attention to the chain length and position. If you set it too long, it won't flush, and too short, it may not flap shut.
Dec 13, 2017 | Home
I have a saniflo system I just installed....what is the best type of toilet paper to use? And should I flush the toilet more than once to insure it stays clean?
many consumers prefer Charmin ultra soft .not necessary unless it doesn't go down the first time . Just wasting water .
Oct 04, 2015 | Saniflo Home
Water Ridge dual flush toilet issue!!
Of course ALL the DIY centers (Lowes, Home Depot, Ace Hardware, Do-It-Best, etc.) sell toilet repair kits. Sounds like you need a flapper replaced in your toilet. Search online for toilet flapper replacement to get guide on DIY.
Nov 10, 2014 | Home
Can a swimming pool be drained into the sewer system?
most cities require waste water from swimming pools be drained into the septic system so it can be treated. Draining into the storm system could lead to your waste water going directly into stream and water reservoirs without treatment, and could land you with a healthy fine.
Aug 04, 2014 | Pool & Spa
Aerobic system's how it operates
A sewage treatment system utilizes two types of bacteria to break down waste products, aerobic and anaerobic. Aerobic bacteria need oxygen to live and do their job of breaking down wastes. Anaerobic bacteria need an absence of oxygen to do their work. The first tank of a septic system contains the anaerobic bacteria the second tank and drain field ( or drywell) contain the aerobic type of bacteria. Anaerobic is needed to break down solids but it cannot do the job alone so when the waste leaves the first tank air is introduced to kill the anaerobic bacteria and the aerobic bacteria is used to finish breaking down the waste.
Hope this helps.
Bob
Sep 06, 2013 | Plumbing
Humming sound in waterline
Check to see if the shut off valve to toilet is turned on all the way, if it is opened all the way more than likely you will need to replace fill valve.
Nov 25, 2012 | Mountain Plumbing Products PVC Pipe Deluxe...
Aquarium water is cloudy
This can happen and will generally clear with time, if you are concerned do a water change. I find that this treatment is more hassle than its worth, if you have a suitable filter seachem denitrate is a good alternative, or he aquarium pure balls.
Sep 21, 2012 | Tetra 16176 3.38 Oz Easy Balance Water...
I wont to replace the sealant from around the tiolet waste pipe, what is the best way of doing this?
turn water supply off to toilet and disconnect water line from bottom of toilet tank. flush toilet to drain tank, use towel to soak up water inside that didnt flush.remove the 2 bolts ( 1 on each side of toilet), lift toilet up and move to one side and lay on it side, scrape off old wax ring from bottom of toilet, scrape off excess wax from pipe on floor. install new wax ring over drain pipe. stand toilet upright and lift straight up over drain hole and reset slowly to make sure each bolt goes through the holes on toilet, replace nuts and washers on toilet and tighten. hook water supply liune back up and turn on water.
Aug 30, 2011 | Home
My jacuzzi toilet doesnt fill with enought water in the bowl to remove waste from porcilin when flushing
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
Jan 29, 2011 | Jacuzzi Bath Era BK37 959 White toilet...
Waste blockage after flushing
MY EXPERIENCE WITH BLOCKAGE PROBLEMS IS: 1. THE WAX RING USED TO SEAL THE BASE HAS OOZED OUT AND REDUCED THE DIAMETER OF THE DRAIN. GET A CLOSET AUGER AND AUGER OUT THE TOILET. 2. FLOAT LEVEL SET IMPROPERLY. ADJUST THE FLOAT SO THE LEVEL OF THE WATER IS EVEN WITH THE WATER LINE MARK INSIDE THE TANK. HOPE THIS HELPS.
Dec 14, 2009 | Kohler Home
Home Logo
Top Mountain Home Experts
Donni Steen
Tom Chichester
Are you a Mountain Home Expert? Answer questions, earn points and help others
