Question about Motorola Mobility RAZR V3
Phone reboots when closed "too hard"
Frequently, the phone "resets" when I shut it and it temporarily loses service as it reboots. This happens unless I close it very gently, and even then it has rebooted for seemingly no reason.
    President:
  • 1,884 Answers
Your main On/Off switch seems to be shorting. have it replaced or repaired.
Posted on Aug 01, 2009
My LG G4 phone is in a reboot loop and won't do anything
This is most likely a hardware problem. Hard reset on android phone do not come with looping and when that happens, the first thing to suspect is the hardware.
I'd advise taking the device to any LG service center close to you. If the smartphone still warranty, this will fasten the process.
Dec 26, 2016 | LG Cell Phones
Alcatel Concorde ZTE keeps rebooting and then screen freeze
Dear Bruce.
Thank you for contacting Fixya. Try to hard reset your phone. It will lost all documents from your phone. Let me know need any guidline for hard reset.
Mar 31, 2014 | T-Mobile Sidekick® 3 Cellular Phone
Zte warp freezes and shuts off when on the phone and in sleep mode
1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously for about 10 seconds until the some option appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.
3.Use Vol+ key and Vol- key to move the cursor to "wipe cache partition" and press camera key to confirm it.
4.After 5 seconds, the cursor will be on "reboot system now" again and press camera key to confirm it. The phone will reboot automatically.
All your personal informations will be deleted
Jan 14, 2013 | ZTE Warp
Phone keeps restarting when I walk into buildings
loss of signal is quite common in many places . especially ones that do not have cell towers located close enough and in mountainous areas.
Jan 15, 2018 | LG Metro Pcs Optimus M 2gb Ms695 Phone...
My ZTE Score keeps rebooting
this sound me softare problem follow the instruction :
press and hold volume down+camera+power button and then press menu button to go to recovery menu and all data will be lost. if my suggestion was helpful please rate my answer.
Jul 08, 2012 | ZTE Score
Every so often my thunderbolt will crash and reboot for no apparent reason. Is this normal or a malfunction with the phone
There are a lot of software issues with some applications that lock up the phone.
Try deleting newly downloaded applications and work backwards until your phone does not reboot again. Any paid for apps can simply be re-downloaded through the Android Market.
If this does not work, attempting a factory reset will be your next step.
Factory Reset
1) Make sure you back up all of your contacts, pictures, etc. Factory Resetting could possibly delete all data off of your microSD card, and you wouldn't want to lose any of it.
2) Once done, from the home screen tap the Menu key.
3) Tap the Settings Option.
4) Under Settings, tap Privacy
5) Select Factory Data Reset
6) Tap Reset Phone.
Once done, your phone should be restored to factory defaults.
If for some reason your phone has decided to continue crashing and rebooting, you must perform a Hard Reset. This will undoubtedly remove contact information.
Hard Reset
  1. Remove the battery and replace it.
  2. Press and hold the Volume Button
  3. Press and hold the Power Button until the phone powers on.
  4. You should see a simple menu showing options such as Fastbook, Recovery, Clear Storage and Simlock.
  5. Using the Volume Down button to navigate, Highlight Clear Storage
  6. Press the Power Button to select Clear Storage
  7. Confirm your decision with Volume Up for Yes. If you feel like backing out, press Volume Down.
Remember, everything will be lost from this point on; so be sure you have EVERYTHING backed up that you do not wish to disappear. This will return your phone to it's original, out-of-the-box condition, software-wise.
If even, after the Hard Reset your phone still reboots, contact your Customer Service department for a warranty replacement.
Jun 03, 2011 | HTC Thunderbolt (8 GB) Smartphone
Error 10054 on windows 7 home priemim
Winsock error 10054 is "Connection reset by peer", or "An existing connection was forcibly closed by the remote host". The error means exactly what it says - the remote host closed the connection unexpectedly. This happens when a connection is aborted, and there is no tcp disconnection handshake (fin, fin ack, ack) , but instead a rst (reset) flag is sent. A reset flag aborts the connection, and can be sent when:
- The device is suddenly stopped, rebooted, or loses its network connection.
- The device uses a "hard close". With IP*Works! a hard close never occurs unless you specifically set the Linger property (IPPort, IPDaemon) to false.
- A "half-open connection" state occurs. That is, when one device not been receiving acknowledgements of the data it has sent, or it receives acknowledgement for an unrecognized sequence or ack number, it will send a rst flag to reset the connection. This particular case could have a variety of its own causes, such as misconfigured proxy/firewall or network quality issues resulting in too many dropped packets.
May 30, 2011 | Cameras
LG LOTUS Starts Up freezes and Reboots after it gets to Sprintspeed Screen
hard rest - you will lose the data - if things does not return to normal after hard reset - an image refalsh should fix the problem - if under warranty - authorized service center should do that for you if out of warranty, there are 3rd party flashers out there who could reflash your phone for a very reasonable price
Sep 01, 2009 | LG Lotus Cell Phone
Motorola Razr V3m randomly/frequently is shutting off..
You need to take the phone to a mobile service center and have them flash the firmware on the phone to correct this issue.
Dec 28, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
53 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
