I found the plastic button plunger on the front becomes too short to actuate the tiny on/off switch inside. Remove the cover and insert a piece or two of thickish paper (like file-folder thickness) between the plastic plunger and the switch. Let it hang back over the circuit board so it will stay in place.
SOURCE: Pioneer Receiver will not come on
press and hold the enter button on the amp then hold the power button down whilst holding the enter button still do this for about 10 seconds then it should reset its self
SOURCE: My RCA STA-3850 receiver will not turn on,...
This could be anything but I would guess you probably have a short in the system.If you could give me more information I may be able to help you better.
hardrocko
SOURCE: RCA STA-3900 standby light on will not turn on
POWER SUPPLY BLOWN FUSE CAUSED FOR A BLOWN OUTPUT TRANSISTOR , DO YOU HAVE THE NUMBER OF THOSE TRANSISTORS??
SOURCE: How do I reset the protection mode on my Optimus
You can not "reset" protection mode. This is an indication of a defect. Disconnect the speaker wires completely and if the protection mode remains, then the problem is internal to the unit and is likely to be shorted output transistors. Expect a parts cost in the $20-$50 range for this repair.
Dan
Testimonial: "Thanks"
SOURCE: I have a Optimus STA-3750 am/fm stereo receiver
I have the same receiver, but have been unable to program it with my Universal Code. I do not have the original remote. Did you find a code that controlled it? I found one website that had the owners manual online, maybe that would help: http://support.radioshack.com/support_audio/doc58/58124.htm
